An Equivalent Uponor PEX Expander Tool - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2016, 07:23 AM   #1
Rewards Points: 464
An equivalent Uponor PEX expander tool
Has anyone tried a refrigeration pipe expander tool in place of the official Wirsbo expander?
Something like this:
http://www.ebay.com/itm/1-4-1-5-8-7-...3D272465808431
Fisher1871 is offline   Reply With Quote
Old 12-02-2016, 07:26 AM   #2
Rewards Points: 464
Re: An equivalent Uponor PEX expander tool
Or possibly this from Wal-mart.
https://www.walmart.com/ip/Manual-Pi...n-Set/40900135
Old 12-02-2016, 08:31 AM   #3
Civil Engineer
Rewards Points: 5,246
They certainly cost less than the Wirsbo tool I own. Probably void the warranty if you use them. If there are any issues, likely would be the amount of expansion, which is probably carefully calibrated in the official tool. I got mine used, still cost several hundred dollars, but probably saved me several thousand dollars when I replaced my pipe.
Old 12-02-2016, 09:18 AM   #4
Rewards Points: 464
Great point concerning the ID of copper vs PEX.
The ID of copper is larger than PEX, so I imagine the expansion by the copper tool would be slightly larger than by the Wirsbo tool.
Given that PEX-A is marketed as being more flexible, resistant to bursting due from a freeze, and that PEX-A has 'shape memory' wants to return to it's original shape, I don't think that slightly larger expansion will cause a problem.
Old 12-02-2016, 12:57 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,050
Ayuh,.... When I discovered plumbin' with pex 7 or 8 years ago, it took me no time to learn to pick a system, then buy the Proper Tools for worry free installations,....
I use the ssteel crimp rings,...
I had a couple of tools used for crimp rings in automotive applications, so I figured, why buy the $100.+ proper tool,.....
After a few connections in my 1st use of the stuff, that I couldn't stop the leaks,....
I went, 'n bought the proper tool,....
No leaks since,....
Old 12-02-2016, 02:12 PM   #6
Rewards Points: 464
That's probably good advice. A $400 expander tool is a tough pill to swallow.
Old 12-02-2016, 11:56 PM   #7
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
If it is for a few jobs you might rent the tool.. other wise there are used pex tools on E of bay that if you look you might find one.
Akpsdvan is offline   Reply With Quote
Expander tool issue Warchild Plumbing 4 03-02-2013 01:03 PM
WIRSBO 3/4" Expander Hand Tool WANTED. CamarosRus Plumbing 11 02-23-2013 05:39 PM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
