Electric Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2016, 10:30 AM   #1
Rewards Points: 22
Electric tankless water heater
Any input out there on good electric tankless water heaters? I am looking for options for a 400 sq ft apartment over a detached garage, so I just need enough flow for a 3/4 bath, kitchen sink and laundry. I am leaning toward tankless as the apartment will not be occupied full time.
wadswob is offline   Reply With Quote
Old 04-28-2016, 11:34 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: Electric tankless water heater
Do you have enough electrical capacity. Like 4 breaker slots and 60-80 amps of capacity. Most of this forum will discourage electric tankless.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 04-28-2016, 11:36 AM   #3
Rewards Points: 22
Yes. I do have the electrical capacity. Why are they discouraged?
Old 04-28-2016, 12:29 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,604
The amps required to operate them usually mean a service upgrade is needed. Some of the units require 3 double pole 40 amp breakers. Most require at least 2 double 40 amps. Gas is better if you have it available.
Old 04-28-2016, 12:33 PM   #5
Oso954's Avatar
Rewards Points: 1,600
Is that detached garage on its own service or fed off a home service. If off the home, you need the capacity to take an 80 amp hit when the house is running at peak. Not many people have that capability.
Depending on the incoming water temperature ( think wintertime temp) and the flow needed, you might possibly need 120 amps of capacity to achieve the desired temperature rise.
Many people find they are looking at several grand of electrical upgrades to install the electric tankless.
It is far easier to support the 30 amp draw of a tank type water heater.
If the apartment is empty for long periods, you could either put the tank type on a low temp setting or shut it down.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
wadswob (04-28-2016)
Tags
Indirect water heater to tankless electric en18703 Plumbing 4 07-29-2015 08:21 AM
What uses less energy: 40-gallon gas water heater, or a 5 GPM electric tankless unit? hellohello Plumbing 2 02-04-2014 08:54 PM
Electric Tankless Water Heater Vs. Gas Tank Water Heater hellohello Plumbing 7 11-26-2013 02:48 PM
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 12:11 PM
