Ele Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2015, 12:28 PM   #1
Rewards Points: 22
Ele water heater
I have a reliance 30 gal ele water heater with two 4500 elements that are 240 v rated on a 30 amp breaker.
I want to use this w/heater at another location with a 220v 20 amp breaker.
Can I just change the elements, say to 3800w and bring the amp rating down to 20 amps.
It shouldn't matter to the two thermostats because they are both rated at 220 v.
emmy
emmy is offline   Reply With Quote
Old 06-30-2015, 12:38 PM   #2
Rewards Points: 80
Theoretically you that works. It won't be certified anymore, unless it's an OEM listed part with a nameplate update sticker. If it's your own house, you should be good either way.
PS. That sounds like its combined 4500W. 30A at 240 is only 7200W
Cheers!
supers05 is offline   Reply With Quote
Old 07-05-2015, 05:05 PM   #3
Rewards Points: 2,650
Just a thought; assuming you can do it technically and legally, I would think your hot water production will suffer, since your energy into the system at max would be decreased by 33%. Would take longer to recover IMO.
bob22 is online now   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
tylernt (07-06-2015)
Old 07-05-2015, 07:34 PM   #4
Rewards Points: 582
you could...but its not reccommended...
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
