Ejector Pump Siphoning Traps On 2nd Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2016, 02:21 PM   #1
Rewards Points: 101
ejector pump siphoning traps on 2nd floor
As per previous threads, I have had a problem with sewage smells coming from the ejector pump especially after it is left for a week. It is more noticeable i winter due to negative pressure but sometimes in summer.
I spent a lot of time trying to seal cracks in the old lid, which is 21" (only 18" sold nowadays). I then did a smoke test and found smoke coming from between the liner and cement, which must mean there is a leak under the ground or where the main waste pipe goes into the liner.
So, there are 2 problems:
- smell / air leak
- siphoning traps
I plan to completely replace the liner and lid and re-cement as the liner is 25 years old. However, I'm still worried that there will be a siphon problem when I do this. How can I solve that? The house has an upstairs toilet plumbed directly into the septic tank and it seems this is the one that gets siphoned (maybe it shares the exit pipe with the pump discharge pipe)?
It is worth noting that there is no main vent stack in this house. I cannot tell if the toilet and other pipes have AAVs but the only vent going up to the roof is a 2" vent that comes from the main ejector itself.
Also,
1/ if I replace it, should the basin be 22" or 30" deep for sewage?
2/ How thick is the concrete layer likely to be to break it up? and
3/ where is the waste pipe likely to be? set into the concrete layer? Might I risk damaging it when I break up all the concrete?
qwertyjjj is offline   Reply With Quote
Old 02-08-2016, 04:21 PM   #2
Rewards Points: 582
- smell / air leak
- siphoning traps
Also,
without a picture of your plumbing system its hard to tell ..but from what you are explaining its all vent related..
Old 02-08-2016, 04:36 PM   #3
Rewards Points: 1,862
"It is worth noting that there is no main vent stack in this house. I cannot tell if the toilet and other pipes have AAVs but the only vent going up to the roof is a 2" vent that comes from the main ejector itself."
This is your problem AAV's do not allow for positive pressure release as a vent to the outside will. So when your pump discharges it will cause trap seals to fail. You need to run a new sump pit vent out the roof or into the current vent going out from the upstairs.
Old 02-08-2016, 09:22 PM   #4
Rewards Points: 101
What will a new sump vent do that the existing one isn't? It already goes up to the roof. Also it seems the only trap being siphoned is the toilet upstairs.
Old 02-09-2016, 03:51 PM   #5
A new vent [my mistake] from your sanitary drain out the roof. You can tie it into your sump pit vent that is going out the roof so you need not cut a new roof hole.
The vent should replace the AAV on the upper floor.
Old 02-09-2016, 04:28 PM   #6
Rewards Points: 101
I'm not even sure there is an aav on 2nd floor above toilet or sink
I noticed an aav behind wall of dishwasher downstairs though but that goes into the sump not the septic pit.
So, maybe toilet or sink need a pipe leading to the sump vent? Sumo vent comes out at basement level and then up the back of house to roof level. So, any pipe from toilet would have to exit the back wall...
Carpet in the basement Packer Backer Flooring 17 11-30-2018 02:10 AM
Floor direction for new hardwood over 1925 hardwood on sleepers? jsimma Flooring 2 07-21-2015 04:47 PM
Power problems on second floor, first floor is fine rarken1 Electrical 21 05-16-2015 11:42 AM
What is the minimum floor space required for a winder staircase vestaviascott Building & Construction 27 05-01-2015 10:36 PM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
