Ejector For Apartment Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2017, 01:20 PM   #1
Steve
STEPHENWANGEL's Avatar
Rewards Points: 27
Ejector for apartment washer
I am planning a bathroom remodel which will involve the installation of a stacking washer/dryer in the apartment where I am. I want to put the washer in a closet which is not close enough to the drain stack to let gravity do its job. Can I use an ejector pump to service just the washer without a laundry sink? I want to route the pipes through the attic space to the waste stack which is about 10 feet away. Anyone?
STEPHENWANGEL is offline   Reply With Quote
Old 04-20-2017, 03:15 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,480
Re: Ejector for apartment washer
The answer is always yes. Just a question of how you get there.
Seeing as washing machines and laundry areas are probably in the top 2 of internal leak areas for the home, you sure you want to further complicate that area and increase that potential?
Old 04-20-2017, 03:30 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,100
Assuming you have permission to do the work, have you figured out where the pump would go? Since ejector pumps are sealed, it would have to be vented (washer drains normally require an air gap at the standpipe, but I doubt that counts). No doubt an actual plumber will drop by with more observations. And the electrical would have to have to comply with the requirements for all the devices.
lenaitch is offline   Reply With Quote
Old 04-20-2017, 04:35 PM   #4
Rewards Points: 1,950
You will absolutely have to have your landlords written approval. Usually apartments without washer's have pay washers that are properly plumbed. Cutting a stack to add your washer depending on the amount of floors your apartment building may cause very serious problems for other tenets. Without the landlords written permission you would be responsible to all damages you have caused to the plumbing and all expenses to bring it back to code. A rental apartment is usually a commercial enterprise and only state licensed tradesmen can perform work on plumbing.
Tags
ejector , laundry , pump , washer
Vibration In High Speed Spin Mode Davy49 Appliances 7 12-30-2014 09:47 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 10:43 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
