Effluent Pumps - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2016, 08:28 AM   #1
JCM
Rewards Points: 4
Question
Effluent pumps
Have had some problem with effluent septic fill up. Not sure if the large rainfall had anything to do with it. I have pumped out a lot of the effluent with a separate pump. The system pump seems to be running (noise and vibration but I am not sure if the pump is actually sending the effluent up the pipes to the field. Is there a way to determine whether the pump is pumping or just running?
JCM is offline   Reply With Quote
Old 06-06-2016, 09:24 AM   #2
Civil Engineer
Rewards Points: 5,246
Re: Effluent pumps
You can find the distribution box, open the cover, and see if the effluent is flowing. Usually the effluent pump empties the chamber relatively quickly, mine will drop my 1000 gallon pump tank from pump on to pump off in less than 20 minutes, so if your pump is running, and the pump chamber is filling up, you either have a serious leak into your pump chamber (broken chamber) or there is a lot of effluent coming from the building sewer (broken sewer). None of this is normal, and I am unclear where you pumped the effluent to with the auxiliary pump.
You may have a saturated field, and the effluent is flowing back into the chamber. This sounds like a job for an experienced septic plumber.
Old 06-07-2016, 11:18 AM   #3
JCM
Rewards Points: 4
Re: Effluent pumps
Thanks for help. Air lock in pipe to field, one hole drilled released flow. Not sure if you got my note yesterday as I'm still trying to figure this site out.
How Many Sump Pumps in finshed Basement ricksample12 Building & Construction 18 01-23-2016 03:15 PM
multiple sump pumps on generator issues pod Electrical 21 11-09-2012 09:46 AM
Portable Generator for 2 Sump Pumps ed3120 Electrical 10 08-10-2012 10:37 PM
Pond pumps tripping GFCI lendosky Electrical 23 12-23-2010 03:22 PM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 06:28 AM
