Dumb Question About How Are Adapters Named... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By DaveNJ
Old 10-05-2016, 05:05 PM   #1
Rewards Points: 38
Dumb question about how are adapters named...
Are adapters named for the gender/sizes they connect or the fittings they contain?
Here's my problem. I need a fitting to connect a G 1/2" female to a 1/2" NPT male pipe.
G 1/2" Female <---- What goes here <----- NPT 1/2" Male
Do I need:
1) G Thread 1/2" Female to NPT Thread 1/2" Male Pipe Fitting Adapter
or
2) G Thread 1/2" Male to NPT Thread 1/2" Female Pipe Fitting Adapter
There's no way to tell from the picture as both are 1/2" and 14 threads. I need 7 of one and 1 of the other and I think I just ordered backwards.
DaveNJ is offline   Reply With Quote
Old 10-05-2016, 07:09 PM   #2
Rewards Points: 1,928
Re: Dumb question about how are adapters named...
Got to look at it from the straight sex angle. Females or on the outside and males insert into females.
G Thread 1/2" Male to NPT Thread 1/2" Female Pipe Fitting Adapter This would work but Your G stuff also has some with O rings.
Old 10-05-2016, 10:17 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,832
Ok Ghost... I gotta ask... what is G stuff....
(I know what the o rings are... my XXXX likes that
MTN REMODEL LLC is offline   Reply With Quote
Old 10-06-2016, 05:41 AM   #4
Rewards Points: 38
LOL. I know about the little boy parts and the little girl parts
I guess my question was confusing, so let me try with an example using what is probably the most common connector in the US, the 1/2" copper elbow. Would you call that a male-to-male connector because it connects the male ends of two pipes, or a female-to-female connector because it has two female parts?
Maybe there is no standard naming convention, or the supply house I ordered from got it wrong, but I ordered based on the fittings I needed on the connector itself, but it seems the adapters are named for the parts they connect.
Old 10-06-2016, 05:56 AM   #5
Rewards Points: 38
G is a variant in the British Standard Pipe (BSP) system, used primarily everywhere on Earth but the US and Canada. G threads are parallel (not tapered) for both the internal and external parts and require some type of bonded seal washer or o-ring facing seal.
It is used in the US for many haudraulic/high-pressure applications and by idiots (like me) who buy shower systems from websites (Wayfair, Overstock) who get their products from China. Some people claim BSP is a superior connection method, but I find it a PITA because of the variation in sealing mechanisms and the difficulty in finding pieces.
MTN REMODEL LLC likes this.
The Following User Says Thank You to DaveNJ For This Useful Post:
MTN REMODEL LLC (10-06-2016)
Old 10-06-2016, 08:19 AM   #6
Rewards Points: 10,784
The two fittings you described are as shown below.
SPS-1 is online now   Reply With Quote
Old 10-06-2016, 08:46 AM   #7
Rewards Points: 38
Thanks for taking the time to sketch that and that's exactly the way I was thinking. Maybe the vendor has mislabeled parts, because this is the fitting that works -- and see how it's labeled (the name describes what that adapter connects -- G Female and NPT Male, not the fittings on the actual adapter: G Male and NPT Female).
This connection (barring the sealing washer) fits like a glove from G to NPT. By Friday, I'll have enough of both adapters to finish (hopefully) and will return the unused ones. Due to shipping and local unavailability, each mistake sets me back 2 to 3 days.
Dumb question about how are adapters named...-assembly-1.jpg   Dumb question about how are adapters named...-img_3173.jpg
Old 10-06-2016, 05:31 PM   #8
No I would just ask for a 1/2" copper 90's or elbows.
1/2 " Street 90"s are a total different type of animal (male to female)
Old 10-06-2016, 05:58 PM   #9
Probably late now, but if you search E-bay, you can do better than $17/each.
Old 10-10-2016, 06:27 AM   #10
Rewards Points: 38
Dang - that would have saved me plenty, especially since I had to source the sealing washers separately and that eBay seller includes them.
In the end, I did confirm that the adapters needed were 1/2" Male G (with sealing washer) x 1/2" Female NPT. The adapters are named for the fittings they contain, not what they connect to.
Probably dumb question about carriage bolts nikeman Building & Construction 18 03-12-2013 08:13 AM
Dumb Question cgoll HVAC 13 03-27-2011 11:24 PM
Dumb question, how do you twist your wires together? Piedmont Electrical 62 04-13-2010 02:50 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Dumb Siding question 1610 CUB Building & Construction 4 08-23-2008 04:08 PM
