Dual Vent Stack? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2016, 06:27 PM   #1
Rewards Points: 177
Dual vent stack?
Doing a renovation to my side porch and I noticed this additional pipe off my main vent (bottom right).
I believe at some point the previous owner had their washer and dryer up here; you can see the vent hole for the dryer in the lower center of the image.
Is this tapped off pipe a vent or a drain?
RCGA is offline   Reply With Quote
Old 02-01-2016, 07:00 PM   #2
Rewards Points: 18,800
From right to left (hard to see because you took the picture to far to the left) looks like a vent with a clean out and an old drain for the washer (that's to low).
Old 02-01-2016, 07:04 PM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
its called a stand pipe( drain) for the washing machine, you can just cap it off or cut it back to the stack and cap..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
ben's plumbing (02-01-2016)
Kitchen Vent Stack Options? short1 Plumbing 26 03-06-2014 07:01 PM
No vent stack in 1'st floor 1/2 bath. Blame home inspector? Hennessey Plumbing 54 03-04-2014 08:50 PM
Venting sink within 16" of vent stack jefsboys Plumbing 11 03-19-2012 12:13 PM
Horizontal section of vent stack teststrips Plumbing 3 09-23-2011 06:18 AM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
