Dual Shower Head Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2015, 12:34 AM   #1
Rewards Points: 68
Smile
Dual Shower head installation
To all the professional plumbers. I need help with Dual Shower heads. Also, I reside in the Great state of Texas. I'm remodeling my master bathroom and upon removing all sheet rock and green board, I see the hot and cold water supply feeding a mixer valve / diverter valve going to the shower head.
I have one of those tub spigots when you pull the button up or in my case the ring down it diverts from the tub to the shower head. What kind of valve do i use to allow water to only one head at a time? When reworking and soldering the new configuration should the pipe that goes to the shower head be branched to two separate pipes with some type of shutoff valve? If so please elaborate what type of valve to use. If not please elaborate.
Thank you pics included.
Newguy2015
Dual Shower head installation-20151016_235455.jpg   Dual Shower head installation-20151016_235445.jpg
Newguy2015 is offline   Reply With Quote
Old 10-17-2015, 03:08 AM   #2
Rewards Points: 6,652
They basically come with a kit with everything you need for the install. It just comes down to how much is in your budget for this.
The problem is that you need enough water pressure that if you are using the shower, someone turning on the garden hose or dishwasher will not starve the shower.
The Following User Says Thank You to gregzoll For This Useful Post:
Newguy2015 (10-17-2015)
Old 10-17-2015, 09:20 AM   #3
Rewards Points: 68
Smile
Gregzoll
Thanks for the speedy reply. I see someone else had the same issue with this and you guys answered it already. Bodine465 had this issue a while back. fixn it posted a pic of a way to do it.
Again Appreciate the quick response....
Newguy
The Following User Says Thank You to Newguy2015 For This Useful Post:
gregzoll (10-17-2015)
Old 10-17-2015, 09:49 AM   #4
Rewards Points: 1,288
yeah, i did it, and it worked great. probably going to do it again at my new (to me) house.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Shower Valve & Head Depth 325_man Plumbing 6 07-11-2014 08:41 PM
Suggestions for 2 head shower control bodine465 Plumbing 10 11-18-2012 08:53 PM
Shower valve for rainshower head Liv Plumbing 0 03-29-2012 10:41 AM
High pressure Shower Head Carloscda Plumbing 9 06-18-2010 12:50 AM
