Dual Sediment Filters (in-line) - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-29-2015, 07:47 AM   #1
Rewards Points: 273
Dual sediment filters (in-line)
Can someone explain, to me, why I would have a second sediment filter inline with the first? I could understand putting two in parallel as to prevent pressure drop and extend the time between changes, but when we had our UV light installed 3 years ago, they added a second filter in series. It just seems like that would be creating more of a pressure drop.
I am slowly changing out the lines because the line from the well is 1" and it was stepped down to 1/2" for the main trunk. I want to make the trunk 3/4" and keep all the legs at 1/2" and during this process, I want to change the filter setup and put them in parallel.
phuz is offline   Reply With Quote
Old 07-29-2015, 07:49 AM   #2
Rewards Points: 5,348
How come you don't just call, "they", the ones who put it in?
Ron
B. Franklin 1759
Old 07-29-2015, 07:53 AM   #3
Rewards Points: 273
Because there's a mixed bag of experts on here, and I would rather hear their opinions on this setup.
Thanks.
Old 07-29-2015, 08:28 AM   #4
Rewards Points: 278
Just a guess. The filters probably had different characteristics when they were first installed.
The first one got the big stuff then the second got the small stuff.
Dan
djlandkpl is offline   Reply With Quote
Old 07-29-2015, 08:52 AM   #5
Rewards Points: 273
The first one has been installed since the beginning. The second installed 3 years ago. Both use the same cartridge filters. Sorry I should have clarified that first.
Old 07-29-2015, 08:53 AM   #6
Rewards Points: 278
That doesn't make sense. Does the second filter get dirty?
Dan
Old 07-29-2015, 08:57 AM   #7
Rewards Points: 273
Good, so it's not just me.
It does get dirty, though.
Old 07-29-2015, 11:43 AM   #8
Thanks.
They don't know what type of filters are installed.
They don't know what the entire setup constitutes.
They don't know what kind of filters are inside the filter units.
But somehow they will know more then the people who put it in.
I think the preferred scenario is:
The people who put it in tell you the why's and wherefores and then:
You come here to see if it makes sense.
Or
There will be post after post after post guessing, "What's Waldo."
Ron
B. Franklin 1759
installing refrigerator ice maker line xnera Plumbing 13 07-11-2013 07:11 PM
Condensate Drain Line Mystery flhvac HVAC 9 06-01-2013 11:08 PM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 07:09 AM
Opinions on sediment filters? Mrdippy Plumbing 0 06-02-2011 07:49 PM
Telephone line static without external filters installed Unregistered Electrical 5 11-21-2004 12:38 PM
