Dripping Outside Spigot - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2015, 02:35 PM   #1
Rewards Points: 904
Dripping Outside spigot
I have an outside spigot that is dripping on/off. I have taken out the stem and tightened the screw on the end of the bibb washer and reinserted the stem back inside the sillcock assembly. I have tightened the packing nut good and snug. It doesn't drip when I put it back together but after a few uses, it begins to drip again. The drip comes from either the area behind the green handle(where the hole is shown in the first picture or behind the packing nut. The green handle is tight(because I can't even remove it). Any ideas of things to try to alleviate this problem? Thanks!
kennykenny is offline   Reply With Quote
Old 07-23-2015, 02:38 PM   #2
Rewards Points: 18,952
Did you replace the washer on the stem while you had it apart?
The packing nut has nothing to do with it leaking where the hose connects.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jmon (07-23-2015), Yodaman (07-23-2015)
Old 07-23-2015, 02:42 PM   #3
Civil Engineer
Rewards Points: 5,246
I can't tell from the photo if that is soldered or threaded, but a new sillcock is generally less than $10, and installing a new one may be simpler than trying to fix an old one.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Gymschu (07-23-2015)
Old 07-23-2015, 02:44 PM   #4
Rewards Points: 904
I did not replace the washer? Can you get the washers at the box stores?
Old 07-23-2015, 02:48 PM   #5
Rewards Points: 904
I have not looked yet but to replace the silcock isn't it typically soldered inside the house? So has to be cut and replaced? I have a feeling that the area inside the house behind the silcock is in an area that is difficult to access. You just can't replace the stem can you if necessary?
Old 07-23-2015, 03:32 PM   #6
Rewards Points: 3,418
Take it to a plumbing supply store, see if they can help you rebuild it.
May just need a new washer as joe suggested.
jmon is offline   Reply With Quote
Old 07-23-2015, 05:28 PM   #7
dd57chevy's Avatar
Rewards Points: 2,976
You can also take the stem to an Ace , Tru value , etc . for a facet washer & whatever seals the packing nut . That is different than mine , which have string graphite packing , also available @ hdwe stores .
dd57chevy is offline   Reply With Quote
Old 07-23-2015, 06:44 PM   #8
Rewards Points: 1,042
Stores around here are using teflon now, no graphite.
Canarywood1 is offline   Reply With Quote
Old 07-23-2015, 08:40 PM   #9
No clue what was used as a washer to seal it, not shown in the picture.
Take it to a hardware or real plumbing store and they will fix you up.
If it's not a simple washer fix then likely someone left the hose on and it froze and will require a total replacement.
dd57chevy (07-23-2015)
Hot Water Heater Spigot Leak ellisje007 Plumbing 10 05-24-2016 03:10 PM
Outside spigot shutoff in townhouse h22lude Plumbing 12 03-04-2015 02:41 PM
Dripping Spigot kennykenny Plumbing 12 08-13-2013 02:33 PM
Cold supply hums loudly, only when running outside spigot. branewrock8 Plumbing 8 01-28-2013 05:15 PM
Dripping Bathroom spigot (Moen) jcase16 Plumbing 7 01-07-2010 08:39 PM
