Drip Pan Under Washing Machine Filled With Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2015, 05:15 PM   #1
Rewards Points: 578
Drip pan under washing machine filled with water
I just noticed that the drip pan under the washing machine is filled with water (see photo).
1) How can I get the water out of the drip pan without removing the heavy washing machine?
2) What might be the cause of the water leakage? And how to fix it?
Thanks!
HomeLearner is offline   Reply With Quote
Old 05-01-2015, 05:55 PM   #2
Rewards Points: 1,942
Check your hoses. Shut the water off to the machine. If no leak found on the hoses call an appliance company.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (05-01-2015)
Old 05-01-2015, 06:23 PM   #3
Rewards Points: 1,414
Think. Most obvious options are towels or wet/dry vac with one of those narrow attachments.
Thanks!
Could be a loose or busted hose. (Most washing machine floods I've come across are from old hoses between the plumbing and the machine that have never been replaced). Might also be something else.
See if there's a drip from the hose connection in back.
The old hoses went regularly; newer hoses last basically forever--just don't buy the cheap one, spend more for the stainless steel.
Tom738 is offline   Reply With Quote
Old 05-01-2015, 07:02 PM   #4
Rewards Points: 1,956
Turkey baster.
ChuckF. is offline   Reply With Quote
The Following 3 Users Say Thank You to ChuckF. For This Useful Post:
HomeLearner (05-02-2015), Tom738 (05-01-2015), tylernt (05-21-2015)
Old 05-02-2015, 03:46 AM   #5
Homerepairguy's Avatar
Rewards Points: 1,114
To add to Ghostmaker's post, one way to check for a slow leak at the hose connections to the washing machine is to wrap some toilet paper around both hose connections. Next morning, see if the toilet paper is wet. Worked for me.
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
mae-ling (05-26-2015)
Old 05-02-2015, 05:39 AM   #6
Rewards Points: 18,974
If you use a shop vac make sure to remove the filter first.
Post the model # and I'll post a site that will suggest some other areas to check for leaks.
Old 05-02-2015, 01:26 PM   #7
Rewards Points: 578
I had the old hoses replaced with new hoses several months ago. But I definitely need to check the connections.
Old 05-02-2015, 01:28 PM   #8
Rewards Points: 578
Originally Posted by ChuckF. View Post
Turkey baster.
Good idea on removing water from the pan!
Old 05-02-2015, 01:29 PM   #9
Rewards Points: 578
HRG
Good idea to use toilet paper to check out the leakage!
Old 05-02-2015, 01:41 PM   #10
Rewards Points: 578
It's a GE model. See the label as shown in the photo for Serial #.
Old 05-02-2015, 01:50 PM   #11
Rewards Points: 578
I visually examined the connections on the back side of the washer, and didn't see anything wrong, although I'll check out with toilet paper.
Looking at the full pan of water, I wonder if the leakage might be from the bottom of the washer.
I post photos of the back (showing the hose connections), the side (showing the hose connections), and the front of the washer for your review.
Drip pan under washing machine filled with water-washingmachineback1.jpg   Drip pan under washing machine filled with water-washingmachineside1.jpg   Drip pan under washing machine filled with water-washingmachinefront1.jpg
Old 05-02-2015, 02:03 PM   #12
Numbers not coming up.
http://www.repairclinic.com/RepairHe...ne-Repair-Help
Old 05-02-2015, 03:16 PM   #13
Rewards Points: 3,454
It's possible, but not likely.
Check where the drain hose exits the washer. Sometimes the drain hose clamp gets worn or drain hose works loose. Reseat hose, replace clamp if leaking. Just another area where it could possibly be leaking from.
jmon is offline   Reply With Quote
Old 05-02-2015, 08:10 PM   #14
Rewards Points: 578
Fantastic idea of using a baster! I was able to drain out the water. It was dirty water; so it seems the drain hose connection.
How can I wrap toilet paper around the connection between the drain hose and the back of the washer? It's deep down there.
Old 05-02-2015, 11:08 PM   #15
If the water was soapy not clean then it is your drain connection for the hose. Yank it out and check it out.
Help! My washing machine filled but won't agitate, etc. idolingaway Appliances 20 03-31-2018 09:12 AM
Washing machine question Underestimater Electrical 3 03-05-2015 09:46 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
What kind of arrester to get for washing machine water hammer Rav Plumbing 4 09-09-2012 10:36 PM
washing machine water for landscaping av-geek Landscaping & Lawn Care 4 04-19-2012 11:46 AM
