Drip Legs - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 3 Post By Bondo
  • 1 Post By Yodaman
  • 1 Post By COLDIRON
Old 02-27-2018, 11:38 AM   #1
Rewards Points: 6,608
Drip Legs
COPIED:
Drip legs were far more important 25 years ago before modern gas refining processes were implemented, now most natural gas is relatively "clean", but it's not like it is all that much more expensive or time consuming to install them.
I suppose with freedom of speech a person can run his diarrhea mouth with whatever nonsense he wants to spit out between his lips.
Old 02-27-2018, 11:46 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,324
Re: Drip Legs
Ayuh,..... 'n every propane supplier will tell ya it's impossible to have water in it too,....
But I know better,.....
'n if it were True, why do they always have an alcohol injector, 'n a jug of ethanol hangin' 'round their shop or on their truck,....
I always put a drip-leg in, myself,....
Old 02-27-2018, 06:17 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,764
Re: Drip Legs
Just installed a Generac 22k generator and it has a built in drip leg. The only problem is that it is inaccessible unless you take panels off. Duh. So I instaled one where the propane enters. Overkill? Probably. Convenient? Sure.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 02-27-2018, 06:36 PM   #4
Property Mgt/Maint
Rewards Points: 8,202
Re: Drip Legs
Probably more likely to catch loose debris coming from inside the iron pipe. From either the mfg process or thread cutting.
Gregsoldtruck79 likes this.
Yodaman is offline   Reply With Quote
Old 02-27-2018, 08:42 PM   #5
Rewards Points: 80
Re: Drip Legs
Our code requires them, with a few exceptions, so we don't have a choice.
You'll often find cutting oil and miscellaneous things in them after several years. Once in a while you'll find various condensate products, including water, but it's not really common these days.
Cheers!
supers05 is offline   Reply With Quote
Old 03-01-2018, 08:16 AM   #6
Rewards Points: 2,074
Re: Drip Legs
Always have used them, one they are required and it's a good place to do a gas test and do a quick air purge for startup.
Yodaman likes this.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Drip edge knowledge.... Paultergeist Roofing/Siding 5 08-27-2016 07:13 AM
Roof drip edge after re-siding job MI-Roger Roofing/Siding 9 02-05-2016 05:58 PM
Drip Edge for Low Slope Roof Martin5 General DIY Discussions 3 10-26-2015 12:52 PM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Drip Legs jamiedolan Plumbing 0 08-27-2009 01:21 PM
