Drinking Fountain Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2014, 03:31 PM   #1
Rewards Points: 24
My daughter received a drinking fountain spigot for Christmas. I installed it yesterday and it works well, but for the fact that it should shoot about 4 inches and it in fact shoots about 15 feet.
I believe I can purchase a regulator for around $50, and I'm sure that's the proper way to do it, but I am reaching the limits of the cost:value ratio of this whole operation.
Is there something less expensive/simpler I can do than install an in-line regulator for this application?
photomikey is offline   Reply With Quote
Old 12-29-2014, 03:43 PM   #2
Rewards Points: 18,976
Sure would help if you posted a picture of this fountain so we can see what your talking about.
Old 12-29-2014, 11:14 PM   #3
Rewards Points: 24
It's this one:
http://www.amazon.com/dp/B005DN8UCY/
Sorry, I was unaware a picture would help.
Old 12-29-2014, 11:24 PM   #4
Bob Sanders's Avatar
Rewards Points: 2,536
Why not place a simple ball or globe valve just before the spigot and it use it as a throttle valve. You'll get higher pressure for maybe a 1/4 second when you initially turn it on but then it should settle to a reasonable pressure and height.
Bob Sanders is offline   Reply With Quote
Old 12-30-2014, 07:01 AM   #5
The flow is adjustable at the fountain.
Just remove that chrome cap and adjust the screw.
Old 12-30-2014, 05:14 PM   #6
Rewards Points: 1,942
This is a solid, heavy, well-built faucet. Given the low price, I was concerned that it would look and/or feel "cheap" but I am very pleased- the finish is great and it works well. It does not come with adjustment instructions so I had to go on the EZ-Flo website and pull up the tech sheet for this which shows where the adjustment screw is (you remove the nut on the side opposite the handle and there is a flat head screw under there). We have high pressure and I turned this down as far as I could and it is still a good 2 foot shoot into the air. However this is installed outside in the garden so the plants are happy to get a little extra water. I'm sure with normal pressure (90 PSI or below) this would be fine.
Check your house water pressure it should not be higher the 80 lbs.
Old 12-30-2014, 10:34 PM   #7
Rewards Points: 24
Thank you both for that tidbit!!
Ghostmaker, do you have a bowl or anything around the faucet, or just the spout spurting out to the garden?
Old 12-31-2014, 05:41 PM   #8
I stole that tid bit from your amazon link in the comments.
Water pressure problems maddog1 Plumbing 7 11-10-2014 05:37 PM
Pressure Tank Waterlogged? Nokesville20182 Plumbing 8 10-10-2014 09:00 AM
Weird water pressure issue in house... tenants moving in today, any ideas? (w/pics) tireshark Plumbing 9 08-19-2014 03:54 PM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
