Drilling Drain Fitting For Dishwasher Hose, What Size Drill Bit? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2015, 05:42 AM   #1
Rewards Points: 16
Drilling drain fitting for dishwasher hose, what size drill bit?
First time dishwasher installation and I need to drill the hole for the drain fitting on my pipe. The internal diameter of the fitting appears to be 14mm. The largest bit under 14mm I have is 10mm. Will that suffice? Or will that create a bottle neck in the draining?
Should I remove the entire piece the fitting is on to make it easier to drill?
Is using a holesaw the best option for this? So I don't create a hole where I'm not supposed to.
wesleysnipes is offline   Reply With Quote
Old 06-28-2015, 05:58 AM   #2
Rewards Points: 3,130
That is NOT how to hook up a dishwasher drain. Replace the tailpiece on your sink's drain with one that has a connection for the dishwasher.
Old 06-28-2015, 06:23 AM   #3
Rewards Points: 16
My piece is exactly this:
Caroma 50mm Combination S And P With Dishwasher Connection
http://www.bunnings.com.au/caroma-50...ction_p4783898
the dishwasher hose fits perfectly over the little left piece, its hollow but blocked off where it meets the main pipe. I dont know if some american plumbing is a bit different because in all of the youtube videos the dishwasher connection piece looks different.
Old 06-28-2015, 07:01 AM   #4
Retired Moderator
Rewards Points: 7,174
Typically,the plug is designed to be knocked out with a flat screw driver---
If you use a drill--get one close in size and ream the hole to allow for full flow.
Old 06-28-2015, 07:30 AM   #5
Rewards Points: 8,655
I've never seen that part but like Mike I agree that it is probably designed like a disposal and meant to be knocked out with a round punch of dull screwdriver. I would remove and do the job in the vice.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 06-28-2015, 08:35 AM   #6
Rewards Points: 474
Go o Lowe's they make an adapter
BrowneBearLLC is offline   Reply With Quote
Dishwasher drain hose installation Myner Plumbing 19 06-12-2015 05:57 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
dishwasher drain hose onelson Plumbing 4 03-16-2010 09:55 PM
Recommendations on appropriate drill for drilling into concrete floor silvergs Building & Construction 8 10-27-2009 05:30 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
