Dressing Stubouts? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2016, 08:47 AM   #1
Rewards Points: 290
Dressing stubouts?
Maybe I'm not searching for the right terms, but I'm having a hard time finding out how to properly dress water supply stubouts?
I have Pex lines in the walls, terminated with copper L shaped stubouts. I want to add 1/4 turn shut offs so that I can install my fixtures.
Under the sink is fine, but for the toilet: is there a way that I can dress the stubout up? I know there are escutcheons, but I'm having a hard time finding chrome sleeves? How do the pros do this?
(I haven't decided on shark-bite, soldered, or compression shut offs)
gizzygone is offline   Reply With Quote
Old 10-09-2016, 10:06 AM   #2
Civil Engineer
Rewards Points: 5,246
Re: Dressing stubouts?
I presume you do not like the look of copper stubouts, at least I think that is what you are saying. If that is the case, you can install chrome stubouts, if you like that look better, or brass stubouts, if that is the look you want. Chrome and brass stubouts come in the same OD as copper, so can be attached to your PEX.
Old 10-09-2016, 10:06 AM   #3
Rewards Points: 18,776
Should not need a sleeve.
Just cut the tube about 1-1/2" from the escutcheon and use a compression stop valve.
A whole lot easier to change the valve in the future.
Ghostmaker (10-09-2016)
Minisplit indoor unit cable dressing to outdoor unit zootjeff HVAC 0 02-29-2016 01:58 PM
Designing a dressing room Sjsmom Interior Decorating 1 07-20-2015 09:13 AM
Tire dressing as permanent concrete sealer pman6 Concrete, Stone & Masonry 3 01-13-2014 09:16 PM
dressing up drainage board in basement rygamer Concrete, Stone & Masonry 6 10-22-2012 08:43 AM
Exterior Window Dressing - Shutter Alternative garysacco Windows and Doors 1 04-22-2012 09:48 PM
