Dreaded Drop Ear Elbow Failure - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree18Likes
Old 07-08-2017, 05:04 PM   #16
Rewards Points: 8
Re: Dreaded drop ear elbow failure
Ok. So clearly I am missing something about pipe sizing or just forgot. I got a cheapo tap and die set at Harbor Freight and the 1/2 inch tap is way to small. I am feeling optimistic about being able to tap/chase the elbow. I'll try and post a pic of what I'm looking at.
But what am I missing about pipe size?
ValleyFur is offline   Reply With Quote
Old 07-08-2017, 05:15 PM   #17
Rewards Points: 6,394
See if this link will help.
You may find a decimal equivalent chart helps explain their decimal numbers.
http://www.engineersedge.com/pipe_schedules.htm
Old 07-09-2017, 01:46 AM   #18
Rewards Points: 1,088
You need a 1/2" NPT (national pipe taper) tap, that would be the correct threads for pipe and the common size for a shower arm.
A tap and die set will not usually include taps or dies for pipe threads, only NC or NF threads for bolts.
SeniorSitizen and ValleyFur like this.
iamrfixit is offline   Reply With Quote
The Following User Says Thank You to iamrfixit For This Useful Post:
ValleyFur (07-10-2017)
Old 07-09-2017, 09:12 AM   #19
Plumber
TheEplumber's Avatar
IMO- you want a pipe extractor, not a tap.
If you have a drop ear that's brass then the threads are probably fine.
If you have a galv. 90 in the wall- perhaps the tap might be needed.
https://www.ridgid.com/us/en/pipe-extractors
Old 07-09-2017, 09:59 AM   #20
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
Any of your friends have a "in wall" inspection camera...... to see what the actual issue is.....?
If you do have a piece of broken shower arm in there.... and you engage an NPT tap.... you'll likely strip/bugger brass thread.
Why don't you at least grab a drop ear at your HD plumbing isle.... and run over and buy a wood dowel that just barely fits in that drop ear... and then test your shower to determine that it is , or is not, a broken off shower arm.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-09-2017, 07:27 PM   #21
hkstroud's Avatar
Rewards Points: 6,694
Pipe extractor at Home Depot, $9.99
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 07-10-2017, 02:27 PM   #22
Rewards Points: 8
Got it. I found and ordered a used 1/2 inch NPT tap with a long shank. I'll give it a shot when it arrives.
Old 07-10-2017, 02:29 PM   #23
Rewards Points: 8
For the suggestions that I should try a pipe extractor, I am trying to post pics of what I am looking at. Got at least one where the threads are in focus and it looks to me like some mangled brass that I may be able to correct.
Old 07-10-2017, 03:07 PM   #24
hkstroud's Avatar
To me that looks like a piece of copper pipe broken off inside the ell. I'd try extractor first.
MTN REMODEL LLC likes this.
Harold,
Old 07-10-2017, 03:13 PM   #25
retired framer
Rewards Points: 15,306
Check the length of the threads on both ends of the arm, they should be the same unless some is left in the fitting.
MTN REMODEL LLC and hkstroud like this.
Old 07-10-2017, 03:19 PM   #26
It looks as that has been acquainted with - Mr. Botch Job - several times over the years and needs to be replaced to be certain there isn't serious water damage in the future.
mark_kershner likes this.
Old 07-10-2017, 04:24 PM   #27
This is another thing some inexperienced may not be aware of.
The farther the tapered tap is run into the fitting, to clean it and renew threads in this instance, the larger the tapered hole becomes, unlike straight threads.
This can cause a condition of too large a hole and the new arm will never tighten before it bottoms out. We don't want a half roll of TEF tape to be a bushing but only like 3-5 wraps to seal.
That's my story and I'm sticken toit.
Old 07-10-2017, 04:56 PM   #28
Hard to tell..... but I'm with HK.....looks like that to me also...
I guess you can't get your finger in there.... but get something that just fits the drop ear... like a wood dowel..... and check if it is a broken shower arm.... and as NEAL says.... your old shower arm might give you a good guess.
And pay attention to SENIOR.... those are tapered thread... and in brass will cut easy.... if it is buggered thread.... you just want to chase the thread... not cut all new thread.
Old 07-10-2017, 05:32 PM   #29
hkstroud's Avatar
Now that's a thinking man.
Harold,
Old 07-10-2017, 06:08 PM   #30
retired framer
When you have screwed as many things as I have.
Drop Ear Elbow too deep in the wall GASCo Plumbing 3 04-06-2017 08:55 PM
Drop gable stick build with lean to roof crecore Building & Construction 19 01-17-2016 03:02 PM
2 2x12 and 1/2 plywood nailed drop beam dmoney1234 Building & Construction 16 08-19-2015 10:39 AM
Can the hot wire be under tension in an overhead drop?? WillK Electrical 15 10-08-2011 01:40 PM
Service drop too low above garage WillK Electrical 1 09-19-2011 12:00 PM
