Draining Laundry Sink Into Washer Stack With Trap In Slab - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 08-14-2016, 09:54 AM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: Draining laundry sink into washer stack with trap in slab
Originally Posted by pkcinna View Post
Right. I already have the p-trap installed since it came with the sink kit. I'm a plumbing novice and my first impression was a p-trap is not needed since I read it is used to prevent gases from coming out the drain and this case the laundry room open vent stack already lets air into the room.
You said in your first post the laundry stand pipe had a trap under the floor. That keeps the sewer gases from the stand pipe. If you do not have a trap on the stand pipe you have issues to deal with.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Anti-wingnut (08-14-2016)
Old 08-14-2016, 10:41 AM   #17
Rewards Points: 1,300
Originally Posted by jeffmattero76 View Post
If you are going to take that route, i would still strongly suggest that you install a P-trap under the sink.
Two traps are a no-no. He is fine feeding the stand-pipe with a straight 1 1/2" trap arm.
The whole apparatus won't be code compliant, but it will be functional and safe. This is one of those situations where close enough suffices.
Anti-wingnut is offline   Reply With Quote
Old 08-16-2016, 03:59 PM   #18
Rewards Points: 38
Thanks everyone! After two days of plumbing and drywall repair all seems to be working. Attached are pictures of plumbing and final result. It turned out to be more difficult since I had to get a reciprocating saw and cast iron cutting blade to lower the main pipe a few inches.
Draining laundry sink into washer stack with trap in slab-sink-drain.jpg   Draining laundry sink into washer stack with trap in slab-sink-final.jpg
pkcinna is offline   Reply With Quote
Old 08-17-2016, 07:25 AM   #19
Rewards Points: 18
Looks great! Congrats!
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 08-17-2016, 05:26 PM   #20
Rewards Points: 1,848
That should pull the trap on that utility tub real well....
TheEplumber likes this.
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
Laundry sink and washer french_guy Plumbing 18 01-20-2015 11:55 AM
Utility Sink; Avoid double trap? Pic included. matt-gp Plumbing 14 11-01-2014 09:07 AM
Sink no longer draining after cleaning trap adnerbs Plumbing 3 11-18-2010 08:31 PM
Water from sink backs up in stack pipe. droy Plumbing 5 01-24-2008 06:39 PM
