Draining The Hot Water System - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 1 Post By joed
  • 1 Post By hkstroud
  • 1 Post By kbartels
  • 2 Post By joed
Old 11-11-2016, 05:12 PM   #1
Rewards Points: 28
Draining the Hot Water System
This seems trivial but:
I'm trying to drain the hot water pipes so I can sweat in a new connection.
I've shut off the water at the main, I've partially drained the water heater (it is lower than the pipe), I've opened all the faucets (even the ones below the pipe).
What gives? This happened to me once before in a different house. Am I missing something fundamental? Does the hot water condense? I'm at a loss.
Help!
kbartels is offline   Reply With Quote
Old 11-11-2016, 05:16 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,572
Re: Draining the Hot Water System
The main may be leaking.
jmon likes this.
Old 11-11-2016, 05:43 PM   #3
Rewards Points: 28
But how would the water get up to this pipe? It's above several open spigots that are not dripping. Plus there are several other stops. But, thanks.
Old 11-11-2016, 07:01 PM   #4
hkstroud's Avatar
Rewards Points: 6,684
Don't forget outside faucets. Sometimes a main valve does not turn off completely.
jmon likes this.
hkstroud is offline   Reply With Quote
Old 11-11-2016, 07:54 PM   #5
Super Moderator
joed's Avatar
When you open both the hot and the cold the water can flow between the two sets of pipes.
Sometimes you just need to wait for the water to drain. Make sure all the hot faucets are open, including any below the pipe you want to solder.
Old 11-11-2016, 07:55 PM   #6
Rewards Points: 3,202
Agree with other posters.
Likely a bad gate valve somewhere not closing all the way keeping enough water in the line.
Another option is to use sharkbyte fittings.
jmon is offline   Reply With Quote
Old 11-11-2016, 08:16 PM   #7
Rewards Points: 28
Last time I used Sharkbite because I was in a hurry to get the job done but the trickle of drops would allow the fitting to get hot enough.
This time I just kept waiting and eventually the dripping became slow enough that the heat from the torch could evaporate the water and still get the joint hot enough for the solder to set.
All is good. Thanks for the input and ideas Good to know that I wasn't missing some plumber magic to get it to stop. Somewhere there much have been a pool of water in a fairly level spot that just kept draining veeeerrrryyyy sloooooly.
jmon likes this.
The Following User Says Thank You to kbartels For This Useful Post:
jmon (11-11-2016)
Old 11-11-2016, 08:19 PM   #8
Glad you got it all figured out and everything is working correctly kb. Yea, sometimes just having patience is the key. Thanks for the update.
Old 11-11-2016, 09:42 PM   #9
Rewards Points: 80
For future reference, If SB fittings won't work for whatever reason, sometimes stuffed bread can slow the tickle enough to weld. (I've never used that on smaller then 1" pipe, but I'm sure it'll work.)
Cheers!
supers05 is offline   Reply With Quote
Old 11-11-2016, 09:52 PM   #10
Super Moderator
joed's Avatar
Another trick that works if the drip is small enough is to take your torch and heat the pipe about foot away from the joint. The water will evaporate before it hits the joint.
SeniorSitizen and supers05 like this.
Old 11-11-2016, 09:53 PM   #11
Rewards Points: 80
I've done that on small pipe. But it's only effective on small drips, or a buddy torch
Cheers!
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 11:56 AM
NEED HELP with AC/ water pump system jin Plumbing 1 07-07-2012 09:45 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
