Drainage For A Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2016, 12:13 PM   #1
Rewards Points: 91
drainage for a water softener
Guys, I'm planning on installing a whole house water softener. I have a spot in my garage with good access to the incoming water pipe which makes for a good install location, but there's no drain there. The otherside of the wall immediately next to the install location has a drain (a bathroom drain, shower and sink), and I have access to that drain via the crawl space. I went and took a look, and it appears to be reasonably new ABS - i think perhaps 4".
For the water softener drain, I have a thin flexible plastic pipe I need to point to a drain. The softener installation instructions make a point of saying the flexible drain pipe shouldn't be inserted into a drain, instead there should be a 1.5" gap between the water softener drain pipe and the drain. I assume I can modify the 4" ABS bathroom drain in the crawl space somehow to accommodate the water softener drain, but I'm not exactly sure what sort of adapter to install to safely accommodate the water softener draining tube, while maintaining the existing drainage pipe for it's function as a bathroom drain? Would appreciate any advice...
thanks,
Matt
mmhendrie is offline   Reply With Quote
Old 01-26-2016, 12:39 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you will have to cut in a 4 x 2 y and run the 2 inch into the garage with a trap...then you can put a 4 x 2 coupling on top of the trap to make a small catch basin and then hang the drain line above that..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
mmhendrie (01-26-2016)
Old 01-26-2016, 02:42 PM   #3
Rewards Points: 91
thanks - would this be a good representation of your idea?:
Old 01-26-2016, 06:57 PM   #4
Retired Moderator
Rewards Points: 7,174
The trap must be at the end of the pipe --with the receptor pipe going verticle directly out of the P-trap.
Most water softener discharge tubes can be run a long way to a drain---
Old 01-26-2016, 07:28 PM   #5
Rewards Points: 1,860
And the discharge must have an Air GAP. Unless you enjoy feces in your water.
Old 01-27-2016, 06:45 PM   #6
Rewards Points: 91
thanks for the input, i've made changes based on your feedback and pasted in a new pic below - does this look ok now? I'm not sure if I would enjoy feces in the water - it sounds intriguing, and i'll give anything a try once. That said, i'm not sure my wife will go for it, so i best plan on the air gap. Is there a device/adapter that helps the softener flexible pipe attach to the end of the rigid pipe, maintaining the gap with a degree of stability, and perhaps even protecting the end of the rigid pipe from capturing other random debris?
Old 01-27-2016, 07:28 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 172
like this is proper
The Following User Says Thank You to TheEplumber For This Useful Post:
mmhendrie (01-27-2016)
Old 01-27-2016, 09:31 PM   #8
Rewards Points: 248
Air gap fitting
One example:
http://www.homedepot.com/p/Keeney-Ma...B&gclsrc=aw.ds
York v45 is offline   Reply With Quote
Old 01-27-2016, 09:46 PM   #9
Rewards Points: 91
perfect - great info as always - really appreciate it!
Tags
abs , adapter , drain , water softener
Tankless Heater and Water Softener Questions jdm001 Appliances 10 12-18-2015 06:44 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Water Softener Drainage Problem hodge23 Plumbing 3 09-26-2011 04:40 PM
