Drain Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2016, 05:02 PM   #1
listo's Avatar
Rewards Points: 107
Drain valve
Is there a type of valve I can use between my house and rain barrel on my sump pump hose, that will let water pass when the pump is on, but then open when the pressure is off so the line can drain
In my crude drawing I'd like the water to go past the black line while the pump is running but then once it stops the water will drain out the black hose.
Not sure if this should be here or gardening or maybe landscaping lol
Sent from my LG-H812 using Tapatalk
listo is offline   Reply With Quote
water heater pressure relief valve drain brizzle Plumbing 24 03-29-2013 08:44 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Drain value dripping MsImmy Plumbing 11 01-29-2011 07:42 AM
Dishwasher drain valve opening WallyWoggle Appliances 1 01-12-2011 08:44 PM
Air Compressor Drain Valve Red Truck Tools 3 02-11-2010 07:36 AM
