Drain Under Dirt Driveway - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2017, 09:18 PM   #1
hohadcr's Avatar
Rewards Points: 466
drain under dirt driveway
I posted another question, but have since abandoned that idea.
Now I need to run a drain from a garage (cement floor to be poured) to a existing drain 15 ft away, acorss a dirt driveway. There will be a utility sink and a emergency floor drain for the garage.
Question:
How deep the drain need to be to avoid freezing?
How deep the drain need to be, and what material it need to be to sustain the dirt driveway?
If you can't quote codes, I would like to hear some common sense.
hohadcr is offline   Reply With Quote
Old 06-23-2017, 05:31 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,490
Re: drain under dirt driveway
How deep is the existing drain? That will be your best clue. Although it happens, drain water seldom freezes, and if you use large enough drain pipe it should stay temperate. I would be more concerned about your sink drain if it has a trap.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-23-2017, 06:46 AM   #3
Rewards Points: 1,054
Cement or corrugated steel pipe with ABS/PVC inside?
What is your frost line?
What is the grade/slope limitations with your setup?
What is traveling over the dirt road load wise? How much erosion will the road be subject to?
clarenceboddick is offline   Reply With Quote
Old 06-23-2017, 07:15 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,228
Ayuh,.... Start at the garage, 2" above the line yer tyin' into,....
Fill the trench with crushed stone,...
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 11:57 AM
Is it necessary to always install a hair catcher on a bathroom floor drain hole? Druidia General DIY Discussions 6 12-07-2016 08:04 PM
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
dirt driveway woes NateHanson Landscaping & Lawn Care 3 04-27-2007 01:42 PM
