Drain Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2015, 09:58 PM   #1
Rewards Points: 14
Drain Trap?
Changed out a leaky garbage disposal in a 7 year old house today and was surprised to see how rusted out the inside of the InSinkErator disposal was. Looked like it had been in salt water!
But my question is about the drain. The instructions show a trap between the disposal and the main drain, which this didn't have. The picture shows the drain set-up. Is this acceptable? It seems to drain O.K. The pipe does run down hill just a little.
mike5511 is offline   Reply With Quote
Old 06-16-2015, 10:50 AM   #2
Special User
Rewards Points: 1,230
No trap is necessary between sink bowls. It's okay for the two adjacent sink bowls (one of which has the disposer and dishwasher discharge) to share the same trap.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
mike5511 (06-16-2015)
Old 06-16-2015, 12:08 PM   #3
Rewards Points: 14
I wondered since the disposer came with a 90 degree drain pipe and showed it going into a trap. Like I said, it seems to work just fine. We have found a lot "cut corners" in this house that shouldn't have been at the price they sold it for new. I had wondered if this wasn't another one.
Old 06-16-2015, 12:14 PM   #4
Special User
The disposer manufacturer is probably just covering themselves legally in their instructions. I suppose there may be some jurisdictions (Canada?) that may not allow two sink bowls to share a trap, but I'm not aware of any US states that prohibit it.
Old 06-16-2015, 12:42 PM   #5
Rewards Points: 474
You look fine to me.
BrowneBearLLC is offline   Reply With Quote
The Following 2 Users Say Thank You to BrowneBearLLC For This Useful Post:
mike5511 (06-16-2015), tylernt (06-16-2015)
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Vanity space for shut-offs and drain / trap mitchell39 Plumbing 1 06-20-2012 12:18 AM
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 09:13 PM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 10:29 PM
