Drain Stub In Concrete Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2016, 09:01 PM   #1
Rewards Points: 12
Drain stub in concrete help
Hey guys,
Earlier today I was fixing a leaking faucet in my basement bathroom (loose water connection), and accidentally lost my balance under the cabinet and broke this drain fitting that is connected to a black pipe that goes directly down into concrete. The rest of this assembly connected to the sink trap. Is there anyway I can repair this without breaking up the concrete? I was thinking to cut the fitting off flush and using a rubber coupler or something and rebuilding the drain trap?
As always, thanks for the advice.
Drain stub in concrete help-imag0039.jpg   Drain stub in concrete help-imag0040.jpg
jshow816 is offline   Reply With Quote
Old 06-20-2016, 02:14 PM   #2
Rewards Points: 781
Re: Drain stub in concrete help
That should be connected to more pvc pipe. Can you show a picture of this black pipe. I would take a multi tool and notch that hub then pry off of pipe
ct18 is offline   Reply With Quote
Old 06-20-2016, 02:23 PM   #3
Rewards Points: 12
The pvc fitting appears to be glued to the black pipe. I tried to pry the two pieces pieces apart but the elbow didn't budge and I don't want to damage the black pipe the goes into the concrete. I'll try and get a pic from inside the broken fitting when I get home. Thanks
Adding a floor drain in concrete ponch37300 Plumbing 5 10-29-2015 09:50 PM
Shower Drain in Concrete Slab Install sharp21 Plumbing 4 08-30-2012 10:51 AM
AC Drain clogged - goes into concrete - no drain outlet at outside evap unit = ???? ReEstate-Rookie HVAC 4 08-27-2012 08:51 AM
Damaged PVC drain needs removed from concrete floor bfensler New Member Introductions 1 01-17-2011 11:02 PM
Adding exterior drain with concrete steps in way steveel Building & Construction 5 09-10-2010 04:23 PM
