DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Plumbing (https://www.diychatroom.com/f7/)
-   -   Drain stub in concrete help (https://www.diychatroom.com/f7/drain-stub-concrete-help-407930/)
jshow816 06-18-2016 09:01 PM
2 Attachment(s)
Hey guys,
Earlier today I was fixing a leaking faucet in my basement bathroom (loose water connection), and accidentally lost my balance under the cabinet and broke this drain fitting that is connected to a black pipe that goes directly down into concrete. The rest of this assembly connected to the sink trap. Is there anyway I can repair this without breaking up the concrete? I was thinking to cut the fitting off flush and using a rubber coupler or something and rebuilding the drain trap? https://goo.gl/photos/XEZEbh2nZ4jBP9g18
As always, thanks for the advice.https://goo.gl/photos/sktKDx7S7k7E3z3dA
ct18 06-20-2016 02:14 PM
Re: Drain stub in concrete help
That should be connected to more pvc pipe. Can you show a picture of this black pipe. I would take a multi tool and notch that hub then pry off of pipe
jshow816 06-20-2016 02:23 PM
The pvc fitting appears to be glued to the black pipe. I tried to pry the two pieces pieces apart but the elbow didn't budge and I don't want to damage the black pipe the goes into the concrete. I'll try and get a pic from inside the broken fitting when I get home. Thanks
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
