Drain Sink Into Ejector Pit - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2016, 06:49 PM   #16
Rewards Points: 126
I certainly do have a lot of opinions. If my count is correct, between here and others I have talked to I now have five different suggestions. Including two which are the same but change the direction of the ty fitting. Very confusing. The sink isn't worth concrete work to me; I am only going to add it if its simple, otherwise I can do without.
I guess I will see which looks easiest to undo, in case it doesnt work, and go that route!
garrett1812 is offline   Reply With Quote
The Following User Says Thank You to garrett1812 For This Useful Post:
ben's plumbing (02-03-2016)
Old 02-03-2016, 06:52 PM   #17
Rewards Points: 1,856
6 foot IPC. vent to trap distance.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 02-03-2016, 07:02 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 168
Thank you.
So now it can be just like the picture, but the trap arm length increases.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 02-03-2016, 08:04 PM   #19
Just run it to the vent on the pump pit. No ones going to lose sleep over it. That way you will not mess up your seals on the pit if you start needing it for the toilet.
Old 02-03-2016, 08:49 PM   #20
Rewards Points: 126
Sorry, not familiar with the terminology, what does this mean?
Old 02-03-2016, 09:03 PM   #21
Rewards Points: 126
Originally Posted by ShtRnsdownhill View Post
that is the drain side, and the fitting you use to tie into the 2 inch is called a ty, you see how the side that goes to the trap, that is called the bull of a T, and how it angles down, well on the vent side you turn it the other way so the bull angles upward..depending on how far away the sink is from the 2 inch vent, you may have to run an additional vent back to the trap..
Just so its clear, diagram would look like this, except with the ty upside down?
Old 02-03-2016, 09:55 PM   #22
Plumber
Rewards Points: 168
No. Do it as your drawing is.
Forget about an upside down fitting.
I haven't heard the term- ty or bull in ages. Must be an east coast thing. Do not put a tee in upside down when used as a drainage fitting.
Old 02-03-2016, 10:32 PM   #23
Rewards Points: 126
Thanks, I was thinking that was the proper way to orient it.
Old 02-03-2016, 10:39 PM   #24
Plumber
Rewards Points: 168
No problem. Sometimes when you get 4 plumbers from 4 regions of the country it gets interesting.... Good luck!
Old 02-03-2016, 10:39 PM   #25
WhatRnsdownhill's Avatar
Rewards Points: 2,220
the pic you have is fine if you dont need to add a vent, thats a ty you are showing, if you need a vent you use the ty but just turn it the other way..if you put your location in that would help on code for your area..and possible nick names that area uses..
WhatRnsdownhill is offline   Reply With Quote
Old 02-03-2016, 10:40 PM   #26
than what does the west coast call that fitting?
Old 02-03-2016, 10:43 PM   #27
Rewards Points: 126
I come from the midwest and we call it a sanitary tee (san-t for short). Never heard ty before either.
Old 02-03-2016, 10:45 PM   #28
its short for tee wye...ty
Old 02-03-2016, 10:56 PM   #29
Plumber
Rewards Points: 168
I know, but I never understood the y part. It's either a tee or its a y.
Old 02-03-2016, 11:03 PM   #30
a T would be straight sides on all 3 outlets, a ty is directional but used for venting just turned opposite from drainage, like a hybird...and a y is only installed 1 way...
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 09:32 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
