Drain Sink Into Ejector Pit - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2016, 08:44 PM   #1
Rewards Points: 126
Drain sink into ejector pit
Hi all!
I have an ejector pit in my basement, which receives a floor drain and rough-ins for a bathroom (not finished, plan to in future). Currently the ejector pit contains a sump pump, not ejector pump.
I would like to add a utility sink to the area, and drain into this pit. I wanted to see if a wet vent would be the best approach, and if this is the correct application.
Thanks all!
Drain sink into ejector pit-img_3182.jpg   Drain sink into ejector pit-img_3180.jpg   Drain sink into ejector pit-img_3180_1.jpg   Drain sink into ejector pit-1.jpg
garrett1812 is offline   Reply With Quote
Old 02-02-2016, 09:07 PM   #2
Rewards Points: 1,852
It's not a wet vent. It's an individual vent and should not cause you an issue. But it is not acceptable pratice to tie a drain into the sump vent.
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (02-03-2016)
Old 02-02-2016, 09:13 PM   #3
Rewards Points: 126
Thanks for the feedback. Is there a better way to plumb this?
Old 02-02-2016, 11:49 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 164
The only other way is to bust up the floor or find a waste line for the current rough in and tie into it.
If it was me- I'd use your plan and consider a pump that would handle any solids that would get by the sink
Old 02-03-2016, 07:09 AM   #5
Rewards Points: 126
What if I put a new hole in the lid of the pit and attached the drain to that?
Old 02-03-2016, 07:11 AM   #6
WhatRnsdownhill's Avatar
Rewards Points: 2,220
that would work, its more of the sump pump is not designed for any type of solids that could end up in the sump, when you convert to a sewer ejector pump you will be fine..
WhatRnsdownhill is offline   Reply With Quote
Old 02-03-2016, 08:08 AM   #7
Rewards Points: 126
Thanks for the reminder on waste. I do have to be careful to put liquids only. The sink has a pretty specific use, so there should be no problem with that.
If draining into a new hole in the lid will the sink be vented via the vent in the pit, or does something else need to be added to make it vented?
Old 02-03-2016, 02:08 PM   #8
you need to vent the sink as if it were hooking into a standard sewer, you can tap into the sump vent...use a 2 x 1 1/2 ty, remember to put ty in so the bull sweeps up for vent..
Old 02-03-2016, 02:20 PM   #9
Rewards Points: 126
Doing this would I tap into the sump vent only for venting, or for draining also?
Old 02-03-2016, 02:27 PM   #10
in reality you could do both..is it 100% code..no, but it will work without any issues...its just up to you, its your house..
Old 02-03-2016, 02:34 PM   #11
Rewards Points: 126
Not sure what you mean by 'bull' and 'ty'. It would look like this?
Thanks!
Old 02-03-2016, 02:51 PM   #12
that is the drain side, and the fitting you use to tie into the 2 inch is called a ty, you see how the side that goes to the trap, that is called the bull of a T, and how it angles down, well on the vent side you turn it the other way so the bull angles upward..depending on how far away the sink is from the 2 inch vent, you may have to run an additional vent back to the trap..
Old 02-03-2016, 02:55 PM   #13
the problem I see down the road for you, is the drain line for the pump is only 1 1/2 inch, minimum for a sewer ejector is 2 inch discharge, you will have to increase that line when you connect a bathroom to it..
Old 02-03-2016, 04:43 PM   #14
Plumber
Rewards Points: 164
Garrett, cut in a 2x1.5" sanitary tee at the sump vent.
Then run an 1.5" trap arm as your picture shows. Support the trap arm from sagging and your done.
My UPC code allows a 1.5" trap arm length of 42" before preventing it. I believe IPC is a bit further in length.
Old 02-03-2016, 04:49 PM   #15
Rewards Points: 582
well you have quite a few options here now don't you...if it were mine..i would bust out concrete tap into the drain line going into pit ...for the 1 1/2 vent needed for tray I would tie onto sump vent back at the wall...
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 09:32 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
