Drain Options - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2015, 09:46 AM   #1
Rewards Points: 8
Drain Options
I am in the process of finishing my basement. I want to put in a bar, however don't have a drain in that area. I know the best thing would be to trench to the pump, however I don't have the $$ for that.
Any suggestions??
Sloppy94 is offline   Reply With Quote
Old 06-03-2015, 09:57 AM   #2
Rewards Points: 1,932
Don't have a bar sink.
Old 06-03-2015, 11:12 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
An ejector pump set up.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 06-03-2015, 12:32 PM   #4
You can use
http://www.globalindustrial.com/p/pl...FZKJaQodxisAag
But the discharge needs to go to 4 inch drain.
Old 06-03-2015, 02:34 PM   #5
Rewards Points: 8
I also found this:
http://www.saniflo.com/
I am concerned about the noise though.
Old 06-03-2015, 03:58 PM   #6
Then tear up the floor.
Old 06-03-2015, 05:35 PM   #7
Rewards Points: 582
you have some options ...choose one...
Old 06-03-2015, 06:57 PM   #8
How did we go from a bar sink to a saniflo toilet?
Old 06-03-2015, 07:37 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Saniflo makes a unit that is basically a small sump and ejector pump. You can plumb a toilet or other drain into it.
Old 06-03-2015, 08:54 PM   #10
Oh ok was wondering if it turned into a bathroom install.
Attic A/C Pan Overflow Drain Pipe - Options? brgmgb HVAC 10 03-17-2014 09:41 PM
Water Softener Drain Options InDashMP3 Plumbing 6 03-06-2014 08:04 PM
Rerouting vanity drain line - Options? interplexr Plumbing 7 11-12-2012 06:17 PM
Very old scupper drain system presents unique replacment challenge-PICS mysterylectric Roofing/Siding 0 10-26-2012 08:05 PM
softener drain options drgkjd Plumbing 6 12-15-2011 10:53 PM
