Drain Lines For Washing Machine Relocation - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2015, 09:36 AM   #1
Rewards Points: 18
drain lines for washing machine relocation
Hello all, I am planning out a relocation of my washing machine and laundry sink in the basement. They will be moved across a room to the opposite wall about 20' away. I am familiar with basic installation techniques, cutting and joining pipe, etc, but I do not have the knowledge to decide what size pipe to use, which fittings, and so on. Any advice is appreciated!
See diagram:
Some questions I have:
-is the plan permissible as shown in the diagram?
-what size pipe to use for drain portion and vent portion?
-what fittings to use - I assume sanitary tees for connecting to old vent, and wye + 1/8 turn for connecting to the new drain line?
-is the dotted vent branch necessary?
-anything I might be missing?
Any other constructive comments are welcome. Thanks in advance for your help. I am happy to provide any other information that might be needed.
Execut1ve is offline   Reply With Quote
Old 10-15-2015, 12:43 PM   #2
Rewards Points: 1,926
Run a vertical vent in between the drains 1.5 inch pipe. The traps for the washer and LT sink must come off horizontal with no rise. Run 2 inch the entire drain. Use a wye for the LT pickup not a tee. Vertical on the vent means 45 degree angle minimum from the vent connection. You will also need a permit in Ohio for inspection. This is a circuit vent. Does anything drain down where your connecting? The vertical drain your tying into must be 3 inch now.
Yet another rough in question - connecting drain lines LHB_Texas Plumbing 2 12-28-2014 09:00 PM
How to vent washing machine drain line nateo Plumbing 1 12-31-2012 04:43 PM
washing machine drain issues lost_punk Plumbing 2 06-19-2012 10:18 AM
Drain lines for Mini Splits dbargaehr HVAC 2 05-24-2011 01:02 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
