Drain Line For Water Heater In Garage - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-09-2015, 09:44 AM   #1
Rewards Points: 348
drain line for water heater in garage
my electric water heater is in a closet in my garage . the drain pan has no line attached to it . I am selling the house and the buyers home inspector
wants a drain line from the pan to somewhere . What does code require for the drain.? home built in 2000 ,concrete floor ,brick exterior
kt82 is offline   Reply With Quote
Old 08-09-2015, 09:55 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 882
You are under no obligation to install a drain. But refusal may nix the sale.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
kt82 (08-09-2015)
Old 08-09-2015, 10:00 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 248
You should call your local code office for confirmation, but I'd pipe it so that it drains onto the garage floor. It needs to be 3/4" minimum.
Or, if you have a hub drain in the closet- pipe to that- turn down a 90 at the hub drain
The Following User Says Thank You to TheEplumber For This Useful Post:
kt82 (08-09-2015)
Water/Sewage Draine Line Addition to Attached Garage CZ DIY Plumbing 9 01-30-2012 08:26 PM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 02:29 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
