Drain Line Into Cleanout Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2015, 12:32 PM   #1
Rewards Points: 90
Drain line into Cleanout pipe
I'm trying to install a water softener and I have to run the drain line which carries salty water. The easiest way for me to do this is to run a host into the cleanout pipe outside of the garage since I don't have any drain lines near the garage.
Is this ok?
What adapter do I need to run a 1/2 host into the Cleanout?
jesusq is offline   Reply With Quote
Old 12-18-2015, 05:25 PM   #2
Rewards Points: 1,854
I would not recommend a direct connection between water you drink and the stuff you flush. Not safe.
Ghostmaker is online now   Reply With Quote
Tags
water softener cleanout
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Drain pipe leak, quick fix? Ultrarunner2017 Plumbing 15 02-15-2012 08:57 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Re-using a drain cleanout mpt1123 Plumbing 0 01-19-2010 05:45 AM
