Drain Dishwasher To Bathroom Plumbing? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2016, 10:51 PM   #1
Junebugsin's Avatar
Rewards Points: 14
Drain dishwasher to bathroom plumbing?
My husband and I are planning to remodel our kitchen. I don't like where my dishwasher is at the present time because its location, when the door is open, prohibits us from accessing several cabinets and the stove/oven. I would like to move it to the wall across from the oven (where you see the orange box). This wall backs up to our bathroom/washroom and the dishwasher's placement will be directly behind where our bathroom sink is located.
Is it feasible to drain the dishwasher into the bathroom sink drain pipe?
Is there anything special that we would need to do to make this kind of a connection?
Any and all help is appreciated!!! Thank you in advance.
Junebugsin is offline   Reply With Quote
Old 07-13-2016, 06:24 AM   #2
Rewards Points: 127
Can't imagine having a dishwasher that isn't next to the sink from a pure practical issue. Carrying a lot of dirty wet dishes across the kitchen seems like a lot of extra work .
A dishwasher tail piece can certainly be physically added to the bathroom sink although you have to remove the drain stopper and its mechanism . Whether it's code to snake the dishwasher drain through the wall to the other room, I don't know . Beat in mind you do need to have a water shutoff for the dishwasher in the same room as the dishwasher .
jimn01 is offline   Reply With Quote
Old 07-13-2016, 07:12 AM   #3
Rewards Points: 18
Re: Drain dishwasher to bathroom plumbing?
From strictly a plumbing point of view, bathroom drain lines are usually 1 1/4" while kitchen drain lines are 1 1/2". Dishwasher tailpieces are 1 1/2". I have never seen a 1 1/4" dishwasher tailpiece. Therefore you would have to convert the bath plumbing to 1 1/2". I am not sure if you could find a strainer for the bath sink that is 1 1/2" AND would fit a bath sink. I am not a pro but have done my share of plumbing in my rentals. Professional plumbers here may have a better answer than mine.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 07-13-2016, 07:46 AM   #4
Rewards Points: 1,274
Kitchen sinks are 36" high (generally speaking) and bath sinks may be 30". You may not have the room for a dishwasher tail tube. The dishwasher drain tube may have to be removed also and that means leaving an access hole from bath to kitchen for the smell and sound to travel. Machine draining noise will be also heard from the bath.
If the vanity drain is that close, you may have to open the wall and redo that part of the drain. If you can replace the kitchen drain to 2", you may be able to extend it to the dishwasher. It's a plumbing rule where bigger size drain (only up to certain distance) is ok without the vent.
carpdad is offline   Reply With Quote
Old 07-13-2016, 09:35 AM   #5
Rewards Points: 1,300
If the lav drains with a 1 1/2" pipe until he hits the WC drain, you'll be exceeding the drain units on that 1 1/2" pipe.
This King County chart is from the UPC and is applicable anywhere the UPC is used and not locally amended otherwise.
http://www.kingcounty.gov/healthserv...nitvalues.aspx
Anti-wingnut is offline   Reply With Quote
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
Wet venting new bathroom group stubborn1 Plumbing 7 01-01-2013 11:14 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
