Drain Conversion Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2017, 12:59 PM   #1
Rewards Points: 2
Question
This might be one of those dumb questions... I want to turn a 2nd bathroom into a laundry room. Is it possible to use/convert the drain from the toilet and use it as a floor drain? Would there be a venting problem? Or should I just seal/cap it off and tile over it? I only have a crawlspace, no basement and septic system. Thanks
Rob17 is offline   Reply With Quote
Old 07-08-2017, 01:26 PM   #2
RRH
Rewards Points: 1,554
Re: Drain Conversion Question
Yes a floor drain can be great for that one time you have a leak/flood. But would have to add a P trap so sewer gas does not come in room.
And remember to add some water or oil once a year so the trap does not dry out and let in the sewer smell.
RRH is offline   Reply With Quote
The Following User Says Thank You to RRH For This Useful Post:
Rob17 (07-08-2017)
Tags
drain , floor , toilet
HVAC drain Pan question partner HVAC 3 11-07-2015 03:46 AM
Basement shower into open floor drain question kwasley Plumbing 7 10-24-2015 06:06 AM
French Drain Question dschribs Landscaping & Lawn Care 7 05-16-2014 08:48 PM
Retaining Wall / French Drain Question bsmith95610 Landscaping & Lawn Care 8 05-18-2012 09:48 AM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 10:55 AM
