Double Sink W/ Garbage Disposal ,shoots Up The Other - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2015, 02:50 PM   #1
Rewards Points: 14
Double sink w/ Garbage Disposal ,shoots up the other
Hi fellow DYIer,
I just bought a home last year and is slowly trying to address some issues around the house. Here is my current project:
Sink A: Sink with no garbage disposal.
Sink B: Sink with garbage disposal.
When using the garbage disposal, there will be food particles that is shot up from the sink A. Attached is the plumbing for the sinks.
From what I understand, I need a baffle T for the sink A. While changing the pipes, I am also looking to replace my garbage disposal as it gets jammed pretty frequently.
trying to achieve:
1. Stop food particles from shooting up sink A when using garbage disposal
2. Change garbage disposal to a new model
3. Put a high loop for the dishwasher outlet
Any help is greatly appreciated.
Double sink w/ Garbage Disposal ,shoots up the other-e3b07417-6086-40d7-a4ad-6d84678a37ef.jpg   Double sink w/ Garbage Disposal ,shoots up the other-e67a4bd2-d1b2-4d03-a775-abec0999f771.jpg
learningToDIY is offline   Reply With Quote
Old 12-30-2015, 03:08 PM   #2
Rewards Points: 1,862
The disposal outlet 90 should go down to the ground. You also need an end outlet waste kit and a flanged 1.5 inch tailpiece 12 inches long to cut to size.
Old 12-30-2015, 03:50 PM   #3
Rewards Points: 14
Hi Ghostmaker, I'm sorry but I am having a hard time visualizing what you are trying to point out to me. I edited the main picture to include an alphabet for each part of the pipes.
If I install an end outlet waste kit, the pipe down Sink A will be straight down, and this will no longer align with the P trap at the bottom to connect to pipe F.
Double sink w/ Garbage Disposal ,shoots up the other-e3b07417-6086-40d7-a4ad-6d84678a37ef-edited.jpg
Old 12-30-2015, 04:32 PM   #4
Rewards Points: 14
Also according to some reference I found online, the Double Sink Center Waste Outlet seems to be the configuration that I have.
Why is the center outlet waste with T baffle not stopping the food from the garbage disposal from shooting up sink A?
Double sink w/ Garbage Disposal ,shoots up the other-disposaldrainconnection.jpg
Old 12-30-2015, 05:23 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 180
Pipe it as the third image shows- end outlet disposal kit.
Also, you tee may not have the correct baffle orientation.
Does your sink drain OK?
Old 12-30-2015, 05:25 PM   #6
Rewards Points: 14
I notice that Sink A drains a little slower than Sink B. What does this indicate?
I am also guessing that the center T baffle orientation is not correct or the inner baffle might be broken. I will remove the center T this long weekend and inspect it.
Old 12-30-2015, 05:29 PM   #7
Rewards Points: 14
Can you also please mention what is the easiest way to remove section D?
Do i have to first remove section F, then E, then B, C, A, then D?
Old 12-30-2015, 08:30 PM   #8
Plumber
Rewards Points: 180
To remove the tee- loosen nut B, E and D
I assume this is to inspect the Tee?
Unscrew the nuts and gently pull and wiggle the pieces apart
Old 01-04-2016, 01:09 PM   #9
Rewards Points: 14
I have managed to change the old T with a baffled T. THe old T has no divider inside to block the flow path from B to A.
With the newly installed T, using the garbage disposal, food particles are no longer shooting up sink A.
Thanks all who helped.
Another question:-
1. I see some rust on the garbage disposal. Is that something to worry about? Why is the garbage disposal rusing on the top where it is mounted?
Double sink w/ Garbage Disposal ,shoots up the other-changed-t.jpg
Old 01-04-2016, 01:46 PM   #10
Rewards Points: 14
2. I seem to notice some particles or mold inside the dishwasher rubber hose. Why is this happening and how do I prevent it? I am looking to make a high loop for the hose, but not sure if it will solve the problem?
Old 01-04-2016, 06:48 PM   #11
Fill up the bowel of your sink on one side and let it drain. If you get anything up the other side you need to snake the drain from the trap downstream. A high loop on your dishwasher hose is also a good idea unless you have a newer dishwasher with the loop built on it.
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 11:39 AM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 02:02 PM
Replacing Metal Ring Around Garbage Disposal in Sink julbox3134 Plumbing 2 09-15-2009 01:19 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 10:27 AM
