Double Shut-off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2015, 11:29 AM   #1
Solidify's Avatar
Rewards Points: 834
Double shut-off valve
A while ago I had my plumber install quarter turn stops on all my lines. Is there a reason he didn't replace the old one here but rather just added the new one on? Is this bad practice?Double shut-off valve-imageuploadedbydiy-chat1424366947.547016.jpg
Solidify is offline   Reply With Quote
Old 02-19-2015, 11:34 AM   #2
jproffer's Avatar
Rewards Points: 452
The reason is because he was lazy. I guess on the up-side, if you have to find one, he saved you 5 minutes worth of his time .
I doubt it will be a problem...just looks hacky.
jproffer is offline   Reply With Quote
Old 02-19-2015, 11:40 AM   #3
Rewards Points: 582
guy was a bum and not a professional at all...and he don't care about his work... or neatness....
Old 02-19-2015, 11:54 AM   #4
Solidify's Avatar
Rewards Points: 834
That's what I was thinking, although jproffer, I wasn't charged per hour, just quoted me a price to install all of them. But I'm relieved this wasn't just me being anal... besides, I learned that the more unnatural connections a line has, the more potential for leaks in the future.
I'm debating whether I should leave it like that or correct it? IF I correct it, won't the cold valve be too close to the stem? maybe he did it to leave more room, and so it's still easy to distinguish the the cold is on the right; if he'd have replaced the old valve, the two valves would be sitting right under each other almost.
The Following User Says Thank You to Solidify For This Useful Post:
ben's plumbing (02-19-2015)
Old 02-19-2015, 04:25 PM   #5
Rewards Points: 1,932
If that other one is not used the proper thing would of removed the dead end and cap it off.
Old 02-19-2015, 04:54 PM   #6
Solidify's Avatar
Rewards Points: 834
What other one?
Old 02-19-2015, 05:42 PM   #7
FIDO...
Rewards Points: 323
Originally Posted by Solidify View Post
What other one?
The one at the bottom of the picture.
Chris130 is offline   Reply With Quote
Old 02-19-2015, 07:03 PM   #8
Solidify's Avatar
Rewards Points: 834
At the moment there's no dishwasher but the stop does just fine at stopping the pressure. No sense in removing the stop to cap it if I plan to install a dishwasher again down the line.
Mixer valve has no shut off is this an option? mrich617 Plumbing 2 11-10-2012 08:41 AM
Toilet Water Shut Off Valve anelson Plumbing 1 07-11-2011 09:42 AM
Water valve will not shut off smcpherson Appliances 2 05-18-2011 09:55 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
