Does A Wye Need To Be Level Or Sloped? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Yodaman
Old 04-14-2017, 06:24 AM   #1
Rewards Points: 960
Does a wye need to be level or sloped?
I'm installing a separate tub and shower drain and was wondering if the wye needs to be level or sloped 1/4" per foot downwards?
Here are pics of each. Still finishing the shower vent line.
jaketrades is offline   Reply With Quote
Old 04-14-2017, 07:24 AM   #2
Property Mgt/Maint
Rewards Points: 8,202
Re: Does a wye need to be level or sloped?
You should put a small slope on the wye. What is up with all those proflex couplings?
You can use the regular coupling for dry fitting, if that is the reason.
jaketrades likes this.
Yodaman is offline   Reply With Quote
Old 04-14-2017, 07:26 AM   #3
Rewards Points: 960
Thanks.
What's a proflex coupling? These are no hub cast iron couplings.
Base cabinet level tolerance? BlueBSH Kitchen & Bath Remodeling 15 09-18-2017 02:11 PM
Does a concrete slab floor need to be level prior to tile installation? Malcolm Flooring 9 06-03-2014 09:39 PM
outdoor concrete stairs - level or slope? jackwashere Building & Construction 16 12-30-2011 08:31 PM
Tub Flange and level tiling DIY Girl Kitchen & Bath Remodeling 2 09-14-2011 07:58 AM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 08:55 AM
