Does PEX Burst When It Freezes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2015, 05:55 PM   #16
Rewards Points: 582
Originally Posted by mathmonger View Post
Is there any compelling reason to slither into the crawl space and secure the tubing to the joists? Or is it fine to just lay it across the floor?
pride of workmanship...and i would strap it up because every time it is being used it could chaff on the floor and cause it to fail by wearing a hole in it..
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (03-10-2015)
Old 03-10-2015, 07:39 PM   #17
Property Mgt/Maint
Rewards Points: 8,202
pex is the way to go in cold a climate, just had a tenant call with a frozen line to the
upstairs bathroom. Inspection revealed on the outside wall caps from blown in insulation had fell out allowing cold air into the wall cavity. GreatStuff, a small temp space heater just to thaw the line and back in business! Thankfully I put in that pex home run!
Yodaman is offline   Reply With Quote
Frozen pipe burst - shark bite repair? Eagle One Plumbing 3 02-08-2014 11:54 AM
Plumbing cleanout burst. How does this happen? ajcrewmisfit Plumbing 11 11-09-2013 09:06 AM
Freezer door ice dispenser freezes up BenW Appliances 2 09-20-2011 03:13 AM
My condensor fan capacitor burst! Ned HVAC 5 07-23-2011 08:36 PM
gas well line to house freezes up fox1 HVAC 0 09-04-2010 08:28 PM
