Does This Look Right? (toilet/bathroom Remodel) - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2015, 07:16 PM   #1
Rewards Points: 6
Exclamation
Does this look right? (toilet/bathroom remodel)
I have a contractor helping remodel my bathroom after discovering a leak.
We are moving the toilet approximately 2-3 feet to allow for a stand up shower once the tub is removed.
The contractor has so far, cut through the foundation to expose all waterlines and plumbing necessary to move the toilet. The current state of the job is attached in the photos below.
My question is, the way in which the toilet drain is currently sitting doesn't look right in reference to what I've read so far. If you can tell by the photos, the pipe is currently set up to drain from the toilet which runs down, then back up to connect with a larger pipe which all the waste runs.
My limited research says I should have a "slope of at least 1/4" per running foot". This is by far the polar opposite. Does anyone know if this is something I should be concerned with? (concerned about the flow if you know what I mean)
Thank you for any and all comments or suggestions.
Does this look right? (toilet/bathroom remodel)-img_4335.jpg   Does this look right? (toilet/bathroom remodel)-img_4332.jpg   Does this look right? (toilet/bathroom remodel)-img_4333.jpg   Does this look right? (toilet/bathroom remodel)-img_4334.jpg   Does this look right? (toilet/bathroom remodel)-img_4331.jpg
GoGators23 is offline   Reply With Quote
Old 09-25-2015, 07:23 PM   #2
Rewards Points: 18,952
Poop does not run up hill.
What's the deal with the flex lines?
Old 09-25-2015, 07:28 PM   #3
Rewards Points: 278
You need a real plumber. That's some fine hackery going on.
Dan
djlandkpl is online now   Reply With Quote
The Following 2 Users Say Thank You to djlandkpl For This Useful Post:
oh'mike (09-25-2015), SHR Plumber (09-26-2015)
Old 09-25-2015, 07:29 PM   #4
Rewards Points: 1,414
I am not a professional, but it doesn't look right to me either. While each fitting has a single trap where you can expect waste to go down and come back up through water, even if this worked it would act as a *second* trap, after the toilet (which is the first trap). IIRC double-trapping is prohibited by code.
Edit: I suppose it is possible someone put this in as a temporary trap so there aren't sewer gases coming up into the house while they're working. This would be a weird way to close the line temporarily, but possible.
Tom738 is offline   Reply With Quote
Old 09-25-2015, 07:29 PM   #5
ZTMAN's Avatar
Rewards Points: 620
Appears to be a temporary set up so the customer could have water overnight
ZTMAN is offline   Reply With Quote
Old 09-25-2015, 07:29 PM   #6
Rewards Points: 6
Thank you joecaption for your comment.
I didn't think poop defied gravity!
I'm not sure what's going on with the flex lines. I'm pretty certain those are being replaced with copper before concrete is poured. It was temporary to keep running water while we were in the house and since he beat the copper piper to hell getting the concrete out.
This current situation is making me nervous!
WTF?
Old 09-25-2015, 07:35 PM   #7
Rewards Points: 6
Good point Tom738 - It may be a temp fix for now... but again odd way to do it especially since he glued it all in?
Old 09-25-2015, 07:41 PM   #8
If that is copper pipe run through the slab it's going to fail at some point.
Most have failed and leaked long ago and where rerouted through the walls, and through the attic.
How it's done depends on where you are, but there's no location mentioned so we have to guess.
Old 09-25-2015, 07:43 PM   #9
Rewards Points: 278
Looks to me like more digging is needed. There's another vent or drain line in the path of the toilet piping that needs to be rerouted.
Dan
Old 09-25-2015, 08:41 PM   #10
Rewards Points: 582
get that contractor out of your house NOW....that is not even a hack job..a hack job would be better.... he don't have a clue....sorry for being so blunt...
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Old 09-25-2015, 09:27 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 240
I couldn't agree more! You have more violations in that bathroom than I've seen in a long time. Don't let him back in.
Better yet, ask to see his license- I bet he doesn't have one.....
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (09-26-2015), SHR Plumber (09-26-2015)
Old 09-26-2015, 07:29 AM   #12
Rewards Points: 1,926
NO NO AND HECK NO! Your being ripped off fire the clown!!!
Do you not have a building department in your area or did you the owner decide to save money and not pull permits?
P.S. You cannot glue the ABS to the white PVC in any way in any code.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (09-26-2015)
Old 09-26-2015, 08:23 AM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 18,404
I'm not a plumbing guy but even I can tell that is all wrong
Old 09-26-2015, 08:43 AM   #14
Rewards Points: 6
I truly appreciate all the comments. So I am in Texas and someone mentioned that the use of copper piping covered in concrete will fail, what is it I am suppose to use? Is what there now sufficient?
Also, sharkbite? Anyone use these for under foundation jobs?
Lastly, anyone here from Austin, Texas and want to give me a bid?
(I feel like I'm up **** creek)
Old 09-26-2015, 11:51 AM   #15
Any copper joints that are buried in the ground you will need to braze them now not solder them. Still fire the clown. Pull your permit and contact your local building department for the list of registered plumbing contractors. Then if you get a chance you may ask the plumbing inspector he may give you a few good un's to call.
Remodel Can Housings For Plaster Ceilings BigJimmy Electrical 4 04-21-2014 06:26 AM
Anyone real familiar with Halo IC 6" Remodel housing? zr800 Electrical 3 01-14-2014 12:01 PM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 05:54 AM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
