Does Anyone See Any Problems With This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2016, 03:26 PM   #1
Rewards Points: 103
Does anyone see any problems with this?
Guys, this is a sump sink for under my basement bar. The two pipes coming out of the wall are a vent and waste line. The waste line pumps up and over the bar area to a ejector pit. Could you guys take a look at. This and comment if I did it right or wrong? I will still install a union on the vent side for easy removal of the pump for replacement. Does pitch of the pipes even matter being it is a pump and not relying on gravity? Any help would be appreciated.
Mike
Mlorek is offline   Reply With Quote
Old 03-13-2016, 03:27 PM   #2
Rewards Points: 103
Re: Does anyone see any problems with this?
One more pic
Old 03-13-2016, 03:40 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 164
You need a check valve and a full port valve on the outlet pipe
The Following User Says Thank You to TheEplumber For This Useful Post:
Mlorek (03-13-2016)
Old 03-13-2016, 03:49 PM   #4
Rewards Points: 103
Thanks you for the quick reply, I guess I should have posted this also, I put a check valve right at the base of the unit, the instructions for install said install it as close as possible to the base.
Old 03-13-2016, 03:51 PM   #5
Rewards Points: 103
By a full port valve will this work? I was going to install it in between the two 90's on the horizontal run there once the cabinets are in. Thank you again for the help.
Mike
Mac Problems l008com PC Repairs & Upgrades 4 06-25-2016 09:17 AM
Power problems on second floor, first floor is fine rarken1 Electrical 21 05-16-2015 11:42 AM
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
