Do You Think This Was Done To Code Via Plumber Or DIY? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2016, 09:30 AM   #1
Rewards Points: 398
Do you think this was done to code via plumber or DIY?
I'm thinking about buying this house as a rental. The plumbing looks shoddy on this part of the house. I believe it used to be a breakfast nook that is now converted to a laundry room.
Malcolm is offline   Reply With Quote
Old 02-24-2016, 09:59 AM   #2
Rewards Points: 3,204
I agree, probably done really quickly/cheaply by diy homeowner to get a washer/dryer hook-up.
Is this property on a slab or foundation? Couple important areas to inspect before purchasing are attic, crawl spaces, basement, plumbing, and electrical. If you get it inspected, which I recommend, use a private unbiased inspector of your own, not a Realtor appointed one. They're in each others pocket. You may be able to negotiate a better deal. Just a suggestion.
jmon is online now   Reply With Quote
Old 02-24-2016, 11:29 AM   #3
Rewards Points: 8,297
To provide an informed opinion one would need to know where and when as codes have changed greatly over the years and by location. It would not meet current standards but it might for the year it was done.
If there is a trap on that drain I would not be overly concerned.
You should be able to visit your local PVA site and determine the number of inspected / approved outlets the house has.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 02-24-2016, 11:58 AM   #4
Rewards Points: 18,762
One other big thing I see is possible mold on that outside wall.
Just looking out that window it sure looks like the grades to high and will cause issues with that wall.
Old 02-24-2016, 12:33 PM   #5
Rewards Points: 173
I agree with Colby and Joe above. There is still a lot you can't see from the picture, but as long as there is a trap and a vent, it is pretty much the same thing you would hope to see. Just outside the wall, not inside.
I would be more concerned about the discoloration on the wall beneath the window.
MrBryan is offline   Reply With Quote
Old 02-25-2016, 12:45 PM   #6
That looks more like dog scunge than mold to me. The oil from their dirty little bodies.
Don't ask.
Colbyt
The Following User Says Thank You to Colbyt For This Useful Post:
pjmarkert (02-26-2016)
Old 02-25-2016, 01:45 PM   #7
Concrete & Masonry
Rewards Points: 506
Purple primer is usually a dead give-awy that it's a DIY job. A number of home & building inspectors have told me in the pst that when they see purple primer, they look harder and longer than they normally would, and usually do so for good reason. That said, it's hard ot tell if there is indeed purple primer or not.....
jomama45 is offline   Reply With Quote
Old 02-25-2016, 04:49 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Many inspectors require purple primer to prove you used it.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Oso954 (02-25-2016)
Old 02-25-2016, 05:21 PM   #9
Concrete & Masonry
Rewards Points: 506
Not here, they simply require a pressure test to prove you used both..........
Old 02-25-2016, 05:22 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Passing a pressure test does not prove you used primer.
Old 02-25-2016, 07:47 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 162
Primer is required for PVC pipe when using normal glue. If my inspectors don't see it, the job fails regardless of a pressure test. And they don't except clear cleaner.
My state has a code amendment now to except 1-step hot glue though.
Our HVAC guys also must extend the primer beyond the fitting hub depth to prove they applied primer their vent lines
Old 02-26-2016, 07:29 AM   #12
Rewards Points: 1,414
Looks like homeowner or craigslist job--most good contractors and plumbers understand that anything outside the wall should look good. This is more quick and dirty.
I would not trust the plumbing in the house to all be good and would definitely walk through the house with tradesmen rather than home inspectors. (Or at least a good independent inspector). The inspection process as a practical matter in real estate is ordinarily about knocking a thousand bucks off the price and only really protects the buyer from defects if there is something *really* glaring that a home inspector can't find any way to accept. Home inspectors who point out problems don't get repeat business from realtors, and often don't know what they're looking at. But contractors and tradesmen have a lifetime of experience fixing other peoples' bad work.
Tom738 is offline   Reply With Quote
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Nevada: Gas line code question bent240lv Plumbing 0 10-04-2011 02:21 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
