Do I Need To Use An Actual Closet Bend Piece? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2016, 12:13 PM   #1
Rewards Points: 310
Do I need to use an actual Closet Bend piece?
Just finishing setup of toilet drain mand now I'm wondering if its code that I use an actual closet bend or can I just have it flow down through a 1 ft pc, 90, then drain stack (mini) ?
EDIT- Researched a bit and looks like ok to drop straight down from toilet with 3" for a 1' until a 90 degree bend
If anyone knows differently please let me know
PandJ is offline   Reply With Quote
Old 04-13-2016, 12:28 PM   #2
JUSTA MEMBER
Rewards Points: 3,220
Re: Do I need to use an actual Closet Bend piece?
The closet elbow is designed to RUSH THE FLUSH past the potential clog point that a 90 causes.
So I would use the closet elbow.
ED
de-nagorg is online now   Reply With Quote
Old 04-13-2016, 12:59 PM   #3
SHEPLMBR's Avatar
Rewards Points: 178
Yes you can. it's not unheard of
SHEPLMBR is offline   Reply With Quote
Bedroom light controlling closet light pullswitch. This sucks. ChrisVanZant Electrical 4 12-01-2015 03:38 PM
How to make beadboard end near sliding closet door zacharinas Remodeling 5 08-03-2013 07:15 PM
Please help with can light layout: Bedroom & Closet Optical1 Electrical 8 04-16-2013 09:09 PM
Suggested depth of bedroom closet Dorado Remodeling 5 03-12-2013 04:19 PM
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 12:14 AM
