Do I Need A Slip Coupling For This? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 01-11-2020, 07:42 PM   #1
Rewards Points: 110
Do I need a slip coupling for this?
I was fixing a leak. I've done this before but on these pipes there isn't a whole lot of room to move them. They are both pretty tightly secured to the wall. Therefore I'm having trouble getting this new pipe connected.
farmerjohn1324 is offline   Reply With Quote
Old 01-11-2020, 08:36 PM   #2
retired framer
Rewards Points: 6,438
Re: Do I need a slip coupling for this?
You might be tight for space.
Do not use flat bottom gables with scissor trusses.
Old 01-11-2020, 09:58 PM   #3
Rewards Points: 1,652
Thats CPVC not PVC. Just use a sharkbyte coupling
Old 01-11-2020, 09:59 PM   #4
Rewards Points: 110
Wouldn't that have the same issue of not being able to squeeze it in there?
Old 01-12-2020, 03:40 AM   #5
hkstroud's Avatar
Rewards Points: 6,416
Remove the CPVC and threaded adapter from the valve. Cut a new piece of CPVC and glue a threaded adapter to it. Screw threaded adapter into valve. Cut to pipe to fit. Remove clamps securing pipe to wall. May have to remove several clamps. Glue regular coupling on one piece. Prime and glue other pipe and coupling, bend pipe out from wall (shorting it) and insert pipe into coupling. Reinstall clamps.
Warming pipe with hair dryer will soften it making it easier to bend.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 01-12-2020, 06:20 AM   #6
Naildriver
chandler48's Avatar
Rewards Points: 1,358
I agree with Harold. The longer pipe you have to work with in free air, the better chance of a good connection will be had. Just loosen at least one or more of the wall clamps and pull it away from the wall and flex in a new pipe with female fitting for the valve. Then glue a coupling on the free end to the existing pipe.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-12-2020, 07:20 AM   #7
retired framer
When you can't figure it out, cheat.
Old 01-12-2020, 09:26 AM   #8
Rewards Points: 2,280
Is the valve plastic too?
huesmann is offline   Reply With Quote
Old 01-12-2020, 10:14 AM   #9
Rewards Points: 110
I went ahead and just pushed that top coupling down a little further than it had to be, then while the glue was still wet I slid it up so that it should be secure to both pipes. This is weird because I've done similar repairs many times and never had this issue. It must just be because there's not enough flexibility in the pipes. Perhaps I should always use PEX pipe where possible. I guess I'll find out the results in about 12 hours when I try to turn the water on.
Nealtw likes this.
Old 01-12-2020, 10:19 AM   #10
Rewards Points: 2,640
This IS the easiest way.
ktkelly is offline   Reply With Quote
Old 01-12-2020, 10:25 AM   #11
Rewards Points: 110
Very aesthetically unpleasing, in my opinion.
Nealtw likes this.
Old 01-12-2020, 10:33 AM   #12
Regardless, it works. When you have a leak and want it gone, you do what's needed.
Besides, looking at the OP's pic, I wouldn't say that is aesthetically pleasing either.
I doubt that anyone is going to stand looking at the pipe and say "why that's terrible to look at!'.
Old 01-12-2020, 10:42 AM   #13
Rewards Points: 2,614
how far below the ground is the 90 elbow connection to horizontal? I might have dug down if it's an easy dig (it's always an easy sandy dig in Florida and never too deep) so I night have dug down to the horizontal pipe and replace all the way from there up including the valve with copper. having CPVC there outside where a lawn equipment or a shovel can damage it easily. I have done the 4 elbow "cheats" but usually it's just for sprinkler PVC lines strangled by big roots where there isn't really any room not even a slip coupling since they are much bigger in diameter.
Don't forget to paint the new pipes, CPVC and sunlight exposure don't go well together. Might consider putting something to protect it from accidental damages.
miamicuse is online now   Reply With Quote
Old 01-12-2020, 10:52 AM   #14
hkstroud's Avatar
All I can say at this point is "Congratulations, good job".
Harold,
Old 01-12-2020, 11:22 AM   #15
Rewards Points: 110
When I went to Home Depot, the slip couplings were referred to as adjustable repair couplings. And they only work with PVC. So I would have had to buy a PVC to CPVC adapter.
