Do I Need Anti-siphon Toilet Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2016, 10:10 AM   #1
Rewards Points: 1,188
Do I need anti-siphon toilet valve?
Hi;
I need to replace a Gerber Pilot Valve in my toilet. I don't necessarily want the Gerber part, as it appears to be obsolete. Everything I look at online is Fluidmaster, which is OK, but I think I want the "400ARHR High-Performance" valve . I certainly don't want the cheapest Fluidmaster model, as they have proven to me to be very unreliable and short-lived.
The problem is, the 400ARHR does not specify anti-siphon, so I assume it does not have that feature. Do I need the anti-siphon feature?
My water supply is standard residential from water utility. I do not have a backflow preventer valve installed in my main line.
Thanks for your help
FW
Ultrarunner2017 is offline   Reply With Quote
Old 11-05-2016, 01:42 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Re: Do I need anti-siphon toilet valve?
Just make sure you air gap the over flow tube you'll be fine..
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-05-2016, 05:04 PM   #3
Rewards Points: 2
It says it is anti-siphon on their web page. http://www.fluidmaster.com/high-perf...performax.html
paul100 is offline   Reply With Quote
The Following 2 Users Say Thank You to paul100 For This Useful Post:
Ghostmaker (11-05-2016), Ultrarunner2017 (11-05-2016)
Old 11-05-2016, 08:12 PM   #4
Thanks! I guess HD just left that out of the description.
Tags
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
Toilet water supply valve compression ring corroded - how to unscrew the nut now? Jenju Plumbing 29 02-19-2013 08:50 PM
Anti Siphon faucet spewing water cai Plumbing 1 08-01-2011 02:48 PM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
