Do I Need An Additional Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2017, 01:40 PM   #1
Rewards Points: 58
Do I need an additional vent?
I'm building a laundry room in the basement.
There is readily accessible plumbing that I can cut into but I don't know if I need to run an additional vent pipe leg, and if so, where do I run it?
I've made a quick, rough representation model, of current fixtures in the basement.
New pipe to be added is in red.
Should I cut it in before or after the vent connection for the sink?
Borisw37 is offline   Reply With Quote
Old 05-15-2017, 04:42 PM   #2
Rewards Points: 1,930
Re: Do I need an additional vent?
You need a stand pipe with a trap and a vent for the washer on its own. The drain if under IPC would need to be 3 inch once your laundry tray drains into the washer drain.
Ghostmaker is online now   Reply With Quote
Direct Vent Water Heater Question kc27 Plumbing 2 02-12-2014 01:39 PM
Installing new Vent pipe for kitchen sink dtweiss74 Plumbing 1 10-21-2012 02:11 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Vent for basement bathroom group chadmills Plumbing 1 10-29-2010 03:03 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
