Do All Frozen Pipes Eventually Burst If Not Thawed Out?? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree11Likes
Old 01-01-2018, 07:41 PM   #1
Rewards Points: 128
Do all frozen pipes eventually burst if not thawed out??
I have a kitchen sink and a utility sink about 10' away using the same half inch hot water copper supply pipe. The kitchen sink is working normally but the utility sink hot water isn't so the problem appears to be a frozen section between the kitchen and the utility sink in the mudroom (on an outside wall)
This freeze has never happened in 40 years.
I spent several hours trying to thaw out the pipe with a hair dryer at the utility sink wall inlet and the basement below with no success.
My question is will the frozen pipe burst in the next few days with below freezing temperatures? Am thinking about removing the wall behind the utility sink to access the pipe risers and insulating them but hate to go through all that if the pipe will not probably burst. Can leaving the hot water valve open lessen the pipe from bursting?
provlima is offline   Reply With Quote
Old 01-01-2018, 07:57 PM   #2
Rewards Points: 18,962
Re: Do all frozen pipes eventually burst if not thawed out??
Left to expand yes they will burst.
Bondo likes this.
Old 01-01-2018, 08:03 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,275
If it is frozen, chances are it already has burst.
Bondo likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-01-2018, 08:21 PM   #4
Rewards Points: 6,322
A possible problem that can occur by leaving the valve open is un-equal pressure. If it has a ice blockage that thaws just enough for the pressure behind it to move the ice slug, it's possible all hell can break loose when the hydrate moves and hits an ell for example with 60 lbs. pressure behind it and 0 pressure on front of it.
Old 01-01-2018, 08:24 PM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Closing hot water tank supply valve & depressurizing hot distribution piping ((by opening hot faucets that flow until they stop) is what is needed to prevent water damages until you either locate/thaw/fix frozen section...
what type of piping in house, copper?
Peace
Bud9051 likes this.
DR P is offline   Reply With Quote
Old 01-01-2018, 08:33 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 2,038
Not necessarily. I had pipes to a mudroom in our old farmhouse that would freeze regularly over a couple of winters until I managed to re-insulate the wall permanently.
But they still could burst. If the source of cold air is widespread along the pipe then the plug of ice could be equally as large, but if it is just a small spot of pipe exposed to the cold then it could be just a single small plug of ice, and that's all it takes. If you are not able to access all of the potentially frozen pipe, then I would seriously consider shutting off the water to the utility sink. Hopefully you have shut-offs at the source sink. If not, seriously consider getting a compression-type shut-off and quickly shutting down the whole house so you can cut the line and install the shut-off.
You could also consider using a plumbing torch, so long as you are careful about not burning the house down. They put out more heat and the copper will carry it along. Don't overheat any one spot. You don't have to melt the ice, just dislodge it from the pipe. Make sure you remove the aerator from the utility sink tap to allow it to pass if it does dislodge.
Bondo, BigJim and mark sr like this.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 01-01-2018, 11:01 PM   #7
Rewards Points: 121
Question
Peace
Just got home to a frozen pipe. I've been trying to thaw with no luck for a few hours now. I don't have access to copper piping at all really.
I'm curious about this approach to depressurizing . I haven't seen it anywhere else. I'm trying to decide what to do for the night if I can't get it thawed.
mklein49 is offline   Reply With Quote
Old 01-02-2018, 03:38 AM   #8
When I was a kid I saw a guy thaw about a 4 ft. length of outdoor exposed copper pipe with his car battery and a pair of jumper cables. Immediate heat. If I recall it took about 1.5 seconds to have flowing water then the flowing water took care of the remainder of the ice.
supers05 likes this.
Old 01-02-2018, 04:12 AM   #9
retired framer
Rewards Points: 15,208
If they are going to break it is to late to worry about.
Cut the pipe and go up thru the floor with a new one.
Old 01-02-2018, 06:56 AM   #10
Peace be with you
DR P's Avatar
if problems on cold side also exists
you will have to turn off all water supply
these procedures wont solve problem but rather
only limits water damages once pipes thaw
how do you limit water damage inside a house?
turn the water flow off...
Peace
Old 01-02-2018, 07:23 AM   #11
Rewards Points: 2,782
I have found pipes expanded significantly that did not burst, but I sure wouldn't want to leave them in place.
One, you need to locate the shutoff for that line in case you spot some water.
DR P has it correct, you need to shut off that line and THEN open the faucet. Open the wall and inspect the entire length. Position any of the old or new insulation between the pipes and the outside (cold) wall. No insulation between the pipes and the inside (warm) wall. Leaving the drywall off and exposing the pipe to the warm room would be best until you can take it all apart and fix it permanently.
Bud
Bud9051 is online now   Reply With Quote
Old 01-02-2018, 07:28 AM   #12
Rewards Points: 8,651
Copper almost always bursts when frozen. Galvanized sometimes does not. 40 years old you might have either.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 01-02-2018, 07:29 AM   #13
retired framer
We don't get to put pipes in outside walls, they all go up thru floor.
Old 01-02-2018, 08:25 AM   #14
Peace be with you
DR P's Avatar
- its gonna get bad when (temps are freezing) colder in FLA & LA, than it is in Anchorage Alaska... just saying
Peace
Old 01-02-2018, 08:28 AM   #15
retired framer
Peace
It's just Canada giving you the cold shoulder.
supers05 and DR P like this.
Tags
freezing conditions , pipes
Help With Water Pipes Above Center Beam of House pasalott Building & Construction 6 03-12-2017 04:34 PM
DIY: How to fix burst or frozen pipes PunctualPlumber Plumbing 0 03-18-2015 11:41 AM
frozen pipes helper Plumbing 3 03-23-2008 12:35 PM
"presumed" frozen water pipes mikeinKy Plumbing 23 01-26-2008 11:32 AM
Assistance to Prevent frozen Pipes in an overhang/candlever PLEASE nitro4you Plumbing 3 11-14-2006 08:41 PM
