DIY (Very) Simple Budget Drain Camera - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2015, 12:10 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 186
Something I noticed in the first image is a lack of a vent. Is the trap vented somehow outside of the picture view?
The Following User Says Thank You to TheEplumber For This Useful Post:
de-nagorg (11-13-2015)
Old 11-21-2015, 06:26 PM   #17
Rewards Points: 34
Cool
Update: Sorry for the delay
I've achieved a significant (~75%) improvement in how fast the shower drains.
I used the "Works" Toilet cleaner method (twice) and unfortunately all it did was clean out everything except for the stuck tile grout (it did give me clearer video of the obstruction):
24 second clip (after 2 attempts, soaking "works" for 15 min. and then flushing with boiling water.)
So, Then i moved up to Muriatic acid. After looking up PVC's resistance to dif concentrations of HCL acid, I decided to buy 20% Muriatic acid. I diluted some to 10% (2 cups total sol. in a pyrex meas. cup) and poured it into the shower drain. After 10 min. I flushed it with cold water, and then then hot water.
I repeated this method a 2nd time. A Lot of the grout is now gone. (18 sec clip)
I will likely do it one more time, but I am very happy with the improvement
DISCLAIMER: This in NOT "How-to" info or guide. Acid is Dangerous. I did research on and used safety precautions (chem. resistant gloves, goggles, respirator mask, good ventilation, etc.) Everything was pretty cheap actually, and easy enough to find...But do your own research if (like me) you have never used strong chemicals in a DIY project before. Thanks!
Khufudude is offline   Reply With Quote
The Following 3 Users Say Thank You to Khufudude For This Useful Post:
123pugsy (11-22-2015), de-nagorg (11-21-2015), TheEplumber (11-21-2015)
Trane XE80 - Drip pan filling up. Drain setup wrong? Please help :) Mognar HVAC 5 06-09-2014 10:52 PM
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 09:32 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
