Diy Sump Pump Replace - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2015, 03:10 PM   #1
Rewards Points: 90
diy sump pump replace
just moved to a home that has a sump pump that works but has no backup power , this isnt a flood zone but has a high water table in lake hiawatha nj , what is a good sump pump with a backup thats not too pricey and should i go with a battery or water power backup and how difficult are they to install?
JoeF77 is offline   Reply With Quote
Old 12-19-2015, 04:29 PM   #2
Rewards Points: 352
go with a zoeller
plumberinlaw is offline   Reply With Quote
Old 12-19-2015, 05:33 PM   #3
Rewards Points: 276
Never thought this existed.
http://www.amazon.com/Basepump-Water.../dp/B000GBUU7G
I doubt you'll find an electric pump with integral back-up and the computer style UPS units don't create an alternating current suitable for operation of a motor or provide the required in-rush current. Unless you're planning on being home with a typical portable generator, you'll likely need one of these.
http://www.amazon.com/Generac-PowerP...p_89%3AGenerac
throrope is offline   Reply With Quote
Old 12-19-2015, 08:42 PM   #4
Rewards Points: 1,854
If you use that water backup make sure you install a testable back flow on it or you may drink your sump water.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (12-20-2015)
Old 12-20-2015, 06:55 AM   #5
Retired Moderator
Rewards Points: 7,174
Sadly, most municipalities do not allow the water powered pumps---at least in this area.
Old 12-20-2015, 10:03 AM   #6
We allow them in Ohio but you must install an RPP back flow that is tested annually.
Sump Pump Pit Alicea21 Plumbing 2 09-28-2014 08:31 AM
1 Sump Pump No Longer Running, The Other Now Runs Majority of Time PolishPete Building & Construction 8 06-14-2014 03:46 AM
Sump pump drain into buried downspouts Chokingdogs Plumbing 1 11-07-2012 11:09 AM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
