Dishwasher Installation Away From Sink-drain Hose - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By TheEplumber
Old 08-16-2017, 03:45 PM   #1
Rewards Points: 6
Question
Dishwasher installation away from sink-drain hose
Hi to everyone reading from Croatia
I have a problem with dishwasher installation(see link in reply post)
DW is about 110-120 cm away from drain, separated by 1 cabinet with drawers.
Red line is solution installed by us. Drain hose is extended with another one, and it goes below cabinets, then up to high loop next to sink, and then to drain.
Plumber installed it badly, hose was laying on floor, without high loop. My husband lifted it a little and we added high loop beside sink.
Would it be better do do high loop on DW ( on back), and then below cabinets, to another high loop beside sink.
Thank you!!!
bjorkish is offline   Reply With Quote
Old 08-16-2017, 03:48 PM   #2
Rewards Points: 6
Re: Dishwasher installation away from sink-drain hose
https://image.ibb.co/n5a8sF/masina_page_001.jpg
Old 08-16-2017, 03:49 PM   #3
Rewards Points: 6
https://ibb.co/iqxMCF
sorry for mess
Old 08-16-2017, 07:35 PM   #4
Rewards Points: 564
You only need one loop. A lot of dishwashers already have a loop installed. I don't think it will cause any issues having a long drain line
BayouRunner is online now   Reply With Quote
Old 08-16-2017, 07:40 PM   #5
retired framer
Rewards Points: 15,348
4 ft or 120 cm is not to far.
Old 08-16-2017, 09:01 PM   #6
hkstroud's Avatar
Rewards Points: 6,694
Purpose of high loop is to prevent dirty water from disposal from entering the dishwasher. Therefore high loop should be at the disposal. You wouldn't want dirty water sitting in drain line.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 08-16-2017, 09:18 PM   #7
Plumber
TheEplumber's Avatar
When I install this kind of layout- I usually go high at the DW and keep it high all the way to the sink- right under the counter top. Is this a better method? Beats me, but it's an easier install
chandler48 likes this.
Old 08-16-2017, 09:32 PM   #8
retired framer
That is the best, no water laying in the hose and little falling back to the washer.
Mop sink, 3-bay sink, only one floor drain - help? summersab Plumbing 9 07-30-2017 12:39 PM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
First time dishwasher installation - drain hose wesleysnipes Plumbing 5 06-17-2015 11:43 AM
Dishwasher drain hose installation Myner Plumbing 19 06-12-2015 05:57 PM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 09:59 AM
