DishWasher Inlet Valve Seemed Stuck. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2016, 05:17 PM   #1
Rewards Points: 129
DishWasher inlet valve seemed stuck.
We had not used our DishWasher (Los Angeles, CA) for six months. A few days ago the first two attempts to start up the DW resulted in no water entering the DW and it shut off by itself. The 3rd time water initially came in slowly (I'm not sure how slowly) and then at the normal rate. The DW finished its full cycle normally.
Is it reasonable to guess that a solenoid valve got stuck with non-use and then vibrated itself free? Should I flush out the DW plumbing with something to keep valves "flexible"? What do you suggest I use?
Thanks for your thoughts.
Daneel is offline   Reply With Quote
Old 12-07-2016, 07:22 AM   #2
Rewards Points: 18,990
Re: DishWasher inlet valve seemed stuck.
Anything's possible.
Those valves are one of the most common items to fail on a DW.
There is no need to flush anything.
Old 12-07-2016, 07:36 PM   #3
Rewards Points: 1,952
Or crap grew in the unused water line that was full of water and now its full of mold. Disconnect the water and flush the line to a bucket.
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
dishwasher stuck on drain cycle DanDaMan Appliances 2 01-03-2014 06:54 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
