Dishwasher Air Gap Elimination - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2015, 03:53 PM   #1
Rewards Points: 100
I'd like to eliminate my air gap in order to accommodate an R-O tap. Due to sink and stone counter space limitations, there's nowhere for R-O that wouldn't look weird. As I understand the function of an air gap, it's to prevent the introduction contaminants into the potable water system. I'm having a hard time visualizing dishwasher debris swimming upstream through my pressurized dishwasher supply line! On another home, our dishwasher drain line led directly into the disposal. We never had an issues I'm aware of. Mind you that home was built in 1967 and was on a private well vs. city water.
So without regard to code (I view this as easily reversible), please explain any potential problems with routing the dishwasher drain directly to the disposal. Or is there a better way to free up the air gap hole in my counter, and still achieve air gap functionality? Thanks!
zippinbye is offline   Reply With Quote
Old 12-21-2015, 04:55 PM   #2
Rewards Points: 1,852
Other then the sun exploding and the stars falling out of the sky. I see no problem as long as you make sure you install a high loop in the hose prior to attaching it to that disposal. Make sure you install that under cabinet hose loop and secure it up there. If your sink does get blocked it will route straight out your dishwasher onto your kitchen floor making a bad mess if you do not put the loop in the hose.
P.S. that is how us rural Ohio'ns do it....
The Following User Says Thank You to Ghostmaker For This Useful Post:
zippinbye (12-22-2015)
Old 12-21-2015, 05:41 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I've installed dozens of dishwashers and never used an air gap. I always put a high loop with a clamp to keep it in place. Never had an issue. But be aware that some codes require the air gap.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Colbyt (12-23-2015), zippinbye (12-22-2015)
Old 12-23-2015, 12:01 PM   #4
Rewards Points: 100
Thanks gentlemen. Deploying solar system debris sheild and proceeding with modification as prescribed!
For sale: gently used air gap assembly in faux stainless steel. ��
Installing dishwasher, are dishwasher panels needed? Lemkie Kitchen & Bath Remodeling 4 02-24-2015 04:13 PM
Building a free standing cabinet around a dishwasher Bootstrapper Kitchen & Bath Remodeling 1 03-25-2014 06:32 PM
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
